Thread: Adhesive tape
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default Adhesive tape
    Hi guys, I'm having problems, I've got a number plate surround which I'm sticking on the back bumper.(I don't want it screwed on), anyway no matter what I use , it just ain't holding it in place, within 48 hours either one side or the other has popped off... Can anyone recommend a good, strong double sided tape....no issue with the cost as long as it works... Thanks..
    Sent from my iPhone using Tapatalk
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    3m double side foam tape(green stuff) is pretty good, but tbh there is going to be a lot of weight on it by the time you add the number plates. Using a hair dryer to heat the bumper will aid the initial adhesion. Can I ask why you don't want to just screw the holders on?
    Regular Member bigdave1701's Avatar
    York
    I think you'd need number plate fixing tape. Try Halfords
    Aug 2009
    I'm thinking I may actually screw the holder to the bumper and then stick the number plate on after...
    Feb 2011
    Selby
    If it's coming unstuck, it's because there's something oily stopping it from sticking properly. You need to really thoroughly clean the surface to get rid of all traces of wax and oil. Use meths or a non-oil based degreaser.
    I've used double sided foam tape to fix number plates on for decades, and they even stand up to car washes.
    Barrow In Furness, Cumbria
    Use some tigerseal. Its not something you're likely to change is it?
    Regular Member Commodore's Avatar
    String o' beads.
    Quote Originally Posted by Chris SRi View Post
    Now that is good gear!
    Aug 2010
    Derbyshire
    No nails double sided tape, from B & Q.
    It comes on a roll or pads just like the number plate sticky pads. It is super strong.
    My front plate kept popping off because it was curved (not the Vx) and it's never moved since.
    Mick
    Aug 2009
    I'll look at getting the no more nails tape. Or tiger seal,, where do you get tiger seal from.. Anyone..
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
  1. what adhesive to use
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2012, 07:06
  2. High temp tape (Engine electrical tape)
    By bigmac in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 19:11
  3. Best name Ever for Adhesive
    By nibblitz in forum Comedy & Humour
    Last Post: 24th June 2011, 21:25
  4. Best Adhesive
    By Ben_ in forum Bodywork & Interior
    Last Post: 23rd March 2011, 17:46
  5. What adhesive?
    By ianm59 in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 12:35
