Results 1 to 10 of 14
Thread: 5-speed gearbox on 6-speed z22yh
    Regular Member Ant SRi's Avatar
    Merseyside
    Default 5-speed gearbox on 6-speed z22yh
    Hi,
    Quick question..
    My 6-speed gearbox has failed on my 56 plate z22YH 2.2 direct Sri, AND the replacement I paid £860 for has failed too
    Can I fit a 5-speed (F23..?) from a pre-facelift z22YH 2.2 direct to my car instead?
    Ant.
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Ive got the same car and mine failed on about 43k, what's yours done? I wrote to VX to complain and see if they'll offer me a contribution towards the rebuild cost.
    Sent from my iPhone when I should be working.
    Merseyside
    47k the first one, then got second hand one fitted, cost me £860 + fitting, that lasted just until the 3 month warranty ran out and then went pop too grrrr....
    I had the 5 speed on my pre-facelift before this car and that did 150k with no issues. Just wondering if the 5 speed would be a replacement for the 6...
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    I didn't take a chance on replacing mine with another dud one off the shelf so got it rebuilt for a grand. All the recon gearboxes I saw came with at least a 12 month/12000 mile warranty, you must have been unlucky.
    How about sticking an auto box on yours?
    South east
    Quote Originally Posted by Gubmint Agent View Post
    That'd be a nightmare with the gearbox ECU and tying it in to the CANbus.
    Merseyside
    Does anyone know if the 5 speed box from a pre-face lift 2.2 direct will fit my facelift 2.2 direct?
    South east
    If you're going to use a completely different gearbox instead of the same model as your failed one, you might as well look into fitting an F40 (6 speed), as it has the advantage of being bullet proof, unlike the M32's that have failed in your car in the past.
    Merseyside
    Yes but the F40 was never fitted to the 2.2 direct (only diesels I think)
    The reason for going for the 5 speed is I thought it might be a direct fit for everything (including the correct ratios) apart from the selector...?
    I don't going back to 5 speed like I had on the pre-facelift. Just want a quick fix.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    it should be a straghit fit a 5 speed AF23 from the identical prefacelift engine.
    South east
    Isn't the AF23 an auto?
  1. 6 speed gearbox
    By billyyoung in forum Engine & Drivetrain
    Last Post: 16th September 2013, 07:54
  2. gearbox problems 6 speed
    By Даниил in forum Engine & Drivetrain
    Last Post: 8th October 2011, 20:43
  3. Z22YH 5 speed or 6 speed
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 11:56
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
z22yh gearbox
z22yh 5 speed
vectra 2.2 direct gearbox
gearbox fit on z22yh engine
vectra 5 speed gearbox to 6 speed
z22yh overhaul
