Thread: Useful info for 1.9 16v CDTi owners
    Regular Member djr69uk's Avatar
    Midlands
    Default Useful info for 1.9 16v CDTi owners
    Guys,
    I'd like to link to this so it gets a bit of exposure:
    http://www.vectra-c.com/forum/showth...=160217&page=4
    I think it's important that 1.9 16v CDTi owners are aware that if they have timing issues or water pump seizes... or the belt snaps etc.. that actually the engine may be able to be revived with a relatively inexpensive fix.
    If it helps one person then it has done its job.
    Cheers.
    Sep 2010
    nice bit of info,.. cheers. Just about to buy a belt for the little lady's 150 CDTI,... VX said they never sell the water pumps and so need not be done,.. whats the thoughts??....
    Engine : 1.9 CDTi
    Always replace the water pump if its driven off the cambelt.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    And I can't understand what dealer would tell you that it doesn't need replaced.
    My dealer keeps equal numbers of water pumps and timing belt kits in stock
    Midlands
    yup do the water pump.
    as a massive coincidence today, the taxi driver that picked me up to take me to the dealers to pick my car up was driving a veccy cdti 150! So I started chatting to him about mine and as soon as I mentioned the tensioner failure he said "broke the rockers did it?"
    i was a bit stunned! then he said. "my water pump seized at 55k. belt sheared and it broke nearly all the rockers. about 60k later the cambelt snapped and broke them again."
    so his veccy has had belt related failure TWICE and neither time has resulted in serious engine damage except to the rockers! he now on nearly 200k.
    so - that's a bizarre coincidence, but a valuable bit of info for sure!
    i have massively restored confidence in my motor now, which incidently is running spot on again.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    When is the intervals for this engine? I had mine done last month the dealer also recommended a new thermostat my cars done 126k.
    Edinburgh
    Thanks for posting this. Makes me feel a bit better about my Vec. I changed its cambelt (first time I've ever done one) and worried about it ever since. I guess it would depend how fast engine was turning how much damage was done? Ie more on a motorway than pulling into a car park?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by djr69uk View Post
    Guys,
    Cheers.
    very good info there mate
    glad you got it sorted out
    so 650 pounds all done yes?
    Midlands
    Quote Originally Posted by Big Knox View Post
    Well this is what I thought, but if you check out the link I posted at the start of this thread, there are a couple of links inside it to other forums. One of them states motorway speed failure - so that would have been worse case sceanrio. However, rockers replaced and everything was running fine again. I don't actually think it matters on the speed. The pistons gives the valves a whack and the rocker breaks which allows the valve to best efforts retreat to the closed position and therefore they stay out of the way after that. I had no compression on 2 cylinders and little on the remainder, so the valves can't have been fully closed but they are clearly ok now! Done about 150 miles since the rockers were replaced and it's running fine. In fact the caterman is going back on it today - I'm missing the extra 50 horses already!
    Midlands
    Quote Originally Posted by vectra ste View Post
    £650 all in - main dealer. The actual rockers are cheap as chips so it makes sense to get all 16 done just in case any of the remainder are stressed or fractured.
    1.9 CDTi 150 Part numbers in case they help anyone who wants to DIY:
    P/N: 93197114 - rocker arm £5.70 (16 = £91.20)
    P/N: 93178683 - B6D2 seal ring £0.56 (4 = £2.24) <- injector seals
    P/N: 93191278 - engine timing £117.00 (1)
    P/N: 93178481 - gasket £8.40 (1) <- rocker cover gasket
    P/N: 55568637 - pump, water £58 (1)
  1. Cdti Owners - look at this pic
    By Leemarksmith in forum Diesel Engine related
    Last Post: 25th May 2017, 14:05
  2. owners of v6 cdti sri info please
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2010, 20:44
  3. Some info required as i cant seem to find it using search. 1.8vvt owners
    By Chris Nock in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 16:07
  4. V6 3.0 CDTi info please
    By zimzunga in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2009, 20:20
  5. 120 or 150 CDTi - Need some info?
    By raymie.d in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2008, 18:58
