Results 1 to 10 of 11
Thread: Wire from engine bay
    Regular Member stuwieb's Avatar
    East London
    Default Wire from engine bay
    Hey all
    I want to run a wire from the engine bay in to the interior of the car.
    Unfortunately I don’t know how to do this
    Can anyone shed some light?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Follow this guide http://www.vectra-c.com/forum/showthread.php?t=15590
    The guide is for installing amp wiring but the same gromit can be used to get what you need through into the cabin
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There is a better place than the one in the how 2. If you pull out your glovebox you will see a huge grommet will most of the loom going through, on the engine site it comes out under the scuttle.
    East London
    Thanks for the info guys.
    I have had a look at this, but unfortunately I don’t know much about cars and could not see theses Grommets?
    Also I have not idea what the “scuttle.” Is
    lol
    Aug 2009
    Wakefield
    I would suggest that if you dont much about cars, then get someone else to help you fit the wire as the last thing you want is to damage a grommet and end up with water leaking into your wiring....
    What are you trying to run the wire for?
    East London
    Quote Originally Posted by MattDC View Post
    Just want to run some 12V speaker wire into the engine bay in the idea of fitting some LEDs, want to run it to the interior light
    East London
    so can anyone please advise what a scuttle.” is?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    thats the bit of plastic runs left to right below windscreen that the wiper arms are fixed over.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    This is where I did it:
    Engine : 1.9 CDTi
    And there is the same on the other side.
  1. Is this an ABS Wire?
    By asgharuk in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 19:32
  2. Wire from engine bay into car?
    Last Post: 15th April 2012, 16:34
  3. wire from engine bay to foot well ?
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2011, 08:04
  4. 12 wire
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 22:02
  5. Where is Ignition Wire located in the engine compartment?
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2010, 07:07
