Results 1 to 10 of 19
Thread: 2.0t exhaust manifold gasket
    Regular Member mann3210's Avatar
    scotland, perth
    Default 2.0t exhaust manifold gasket
    Hey does anyone know the easiest way to change the gasket between the engine & exhaust manifold, I think it's leaking as I never changed it when I took the manifold off, can I remove it with out taking the turbo completely off? It sounds like a diesel when under load
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    I doubt your oil and water lines will flex enough for you and your downpipe will not move for that either.. best to drop off the turbo and also replace the gasket between that and manifold..
    i have the gasket part numbers if you need them
    check for escaping gas first though... with the engine running hold a lit ciggy or a joss stick above the manifold to see if the smoke is being blown around by escaping exhaust gas etc
    scotland, perth
    thats a great idea, is the part number - 12786717? so if i take the turbo off the exhaust manifold i wont have to take the fluid pipes off? im going to unhook the exhaust system & support it with stands for a little bit of play. its really rattley at the exhaust manifold it can only be me not changing the gasket thats causing it to blow
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    escaping exhaust gas under load can make an awful sound which believe it or not can sound like a rattle... i mentioned this in your other thread, you would have been better off sticking to one thread..
    the turbo to manifold gasket is: 90537716
    the manifold to engine block gasket is: 12786717
    scotland, perth
    haha yeah il stick to this thread mate, i fitted a new gasket to the manifold to turbo as it came with a kit, ill v.o.r the gasket for tomorrow, its getting annoying that i cant enjoy the new turbo as much as i should, ill get there in the end, hopefully
    scotland, perth
    Iv orders the gasket for Saturday, less than £1!!! There on the Internet for £10! I couldn't belive it, we're going to try and slip the gasket in behind the manifold once we loosen off the nuts!
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    cool, let us know if that method works. its been a while since i did my turbo so can't remember the clearance and stud lengths..
    scotland, perth
    Well me & 1 of my mechanic mates just spent the last 2hours taking the exhaust nuts off 3 came off with the studs but we prised the manifold back & managed to slip the old gasket out! So I didn't have to take the turbo off! Yes! Result! All we took off was the rear coolant pipe which ****ed out everywhere but I don't mind I'll get some coolant from Vx when I pick the new gasket up tomorrow, the old gasket is worn & black soot at the o/s end of the gasket so were thinking it's been that that's been the noise, oh & there was a heat Sheild between the turbo & manifold, total disaster with the bottom nut, so ended up bending it out the way lol
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    so you managed to get the manifold clear of the studs that remained to get the old gasket off them...?
    scotland, perth
    Yeah we thought we needed to try it & it paid off with ease. Iv got to clean the engine & manifold tomorrow before I fit the gasket then bolt it back up then coolant top up then a run, hopefully it will put an end to the tractor replica lol
  1. Egr pipe to manifold gasket
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 23rd January 2013, 19:07
  2. Price for Possible Gasket and Manifold Repair = please
    By HITFACTORY1403 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2011, 23:43
  3. vectra sri turbo manifold gasket
    By robsriturbo in forum Engine & Drivetrain
    Last Post: 9th June 2010, 16:55
  4. Exhaust Manifold for 1.8 VVT
    By Gray16v in forum Petrol Engine related
    Last Post: 23rd December 2009, 23:34
  5. exhaust manifold
    By KeefyB in forum Petrol Engine related
    Last Post: 19th September 2009, 22:01
