Thread: Plasti-dip-tips
    Regular Member dlp's Avatar
    Mar 2011
    Cottesmore, Rutland
    Default Plasti-dip-tips
    I saw a pic on here of a pre-face grill which had the chrome blacked out. Thought I might try this with Plasti-dip as it seems its the most reversible option if I don't like it/sell the car/change my mind. And it's cheap. And it may be easier than painting.
    Anyone got any tips or experience with this?
    I guess that 1 can will do the grill, do I *need* to prime it first (I'm assuming the chrome is metal not plastic?). How extensive is the coverage (ie should I totally mask the grill bit or just coat that too)? Should I key the surface first, if so this could be a dealbreaker as it sort of defeats the point of this option...
    Chars
    Sent from my MB860 using Tapatalk 2
    Regular Member bigbnlr's Avatar
    Belfast
    It's plastic, just rub it down, prime with plastic primer and then paint & lacquer done
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    There's one on eBay at min already blacked out for 15 iirc?
    But I'd just do as above...
    Mar 2011
    Cottesmore, Rutland
    Cheers chaps, hadn't seen the one on ebay - duly noted
    Regular Member PORKBALLS29's Avatar
    Epping
    With Plastidip you don't need to rub down or primer or lacquer just make sure the surface is clean and spray it. 3-4 even coats will do and hey presto its all done. I did my Octi grill recently and its very easy to use here's my thread of how it turned out http://www.vectra-c.com/forum/showthread.php?t=159513 hope this helps. As its a plastic/rubber spray it will last much longer than spraying with paint etc and no worries with stone chips etc.
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Where'd you get hold of this stuff? It looks good.
    Edit: scratch that, Google has sorted it for me!
    Mar 2011
    Cottesmore, Rutland
    The grill is just a test for me tbh.
    Long term plan is to smoke wrap the chrome (grille - stripped first, window trim, boot trim), do the chrome fog mod (smoke wrapped), anthracite/smoke alloys with some filler to make them look a bit different (early 17in snowies), get some sun blinds. Remove the external aerial, fit a blanking grommet and fit an internal one.
    And then matte black plasti-dip the whole car....
    It's currently (poor quality) flame red so when time comes to sell it should look alright with the plasti-dip peeled off and dark chrome trim/wheels.
    Any thoughts?
  1. Been Messing About with Plasti Dip!
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 29th November 2012, 22:04
  2. ~~~Top Tips~~~
    By Das in forum Detailing and Car Care Discussion
    Last Post: 27th April 2011, 21:35
  3. BBQ tips
    By steve1975l in forum The 'Off Topic' room
    Last Post: 21st August 2008, 07:15
  4. Gym tips
    By Big Sig in forum General Chat
    Last Post: 12th August 2008, 13:11
  5. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
