Thread: Boot wont open
    Regular Member LeylandRick's Avatar
    Jan 2012
    Lancashire
    Default Boot wont open
    Hello guys. The boot on my Siggy wont open. yesterday when i pressed fob it popped, but when i press the handle under boot lid it wont do anything, wont open passed the "pop". i can push it shut and then pop it again and thats it.... it did whurr at first now not at all...
    is there a manual release anywhere, or somehere to put a key? i cant bleeding find one - lol
    cheers all
    2004 Signum 1.9CDTI
    South east
    Look on the trim on the inside of the bootlid, should be a small slot to put a screwdriver in - that's the manual override I believe. The fault is caused by a small ball bearing in the exterior handle getting gummed up and failing to trigger the microswitch. Either replace the handle mechanism (there's a revised part available from Vx that does away with the ball bearing), or remove the old one and clean the mechanism.
    Jan 2012
    Lancashire
    Cheers Rebellion. All i could see was a gromet in the bottom centre of the trim, that when u pop it off there seems to be a square socket. Is this what your referring to? if so i do i try and twist it, or is there something else i should be looking for?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Give it a quick bash on the outside with the side of your fist. it should then open the little switch is getting stuck. Ive had to clean mine up on two occasions since Ive owned the car. They get all gunge up with the winter damp weather.
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by LeylandRick View Post
    Your key or a screw driver will fit into the slot. give it a twist and this will open it from the inside.
    midlands
    On my signum i had to peel the rubber that opens the boot WD40 the mech and cut the rubber to get it back. When it whirrs i give it a spray of WD40 - been fine since
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Yes thats what you are looking for.
  1. Boot wont open
    By pdiddams10 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2016, 00:52
  2. Boot wont open???
    By fastcarmanaic in forum Bodywork & Interior
    Last Post: 18th November 2010, 15:14
  3. Boot wont open help!!
    By lukesignum in forum Bodywork & Interior
    Last Post: 6th March 2010, 15:21
  4. Boot wont open!
    By Netstar in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 14:13
  5. Boot wont open !!
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 13:43
