Results 1 to 3 of 3
Thread: Annoying hesitation
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    confused Annoying hesitation
    Evening all,
    04 1.9 Cdti 120 8v
    I have an annoying hesitation at low revs (~1k).
    It happens for example when either slowly rolling in traffic in 2nd then applying throttle gently, if you have to lift off then apply throttle again, there seems to be a slight hesitation.
    The car has recently had a cambelt kit, new waterpump, oil & filter change and fuel filter change.
    Millers diesel additive used at every tankful, and the car trawls the motorway for 70 miles daily after gently being warmed up.
    I don't tend to drive very aggresively and wondering if giving it the beans for a few miles might get rid of it.
    I will tonight be changing the air filter and pollen filter to complete the service as she's just hit 100k.
    Any thoughts on the common causes of this?
    Fanks and all that....
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Time for an EGR and boost sensor clean, and throttle butterfy clean whilst its off. It may be worth checking all the turbo vac pipes too for perishing on the elbows.
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    EGR, boost sensor, and throttle body cleaned ion Feb when I replaced the thermostat.....
    I will have to start checking the boost hoses tomorrow.
    May have to clear the cobwebs off it tonight on the way home from work and see if that helps too.
  1. 2.0T Hesitation
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 8th May 2012, 12:48
  2. Hesitation help
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 21:53
  3. Hesitation please help??
    By sowter28 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 17:43
  4. hesitation
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 1st April 2010, 18:44
  5. Hesitation
    By Deadman in forum Engine & Drivetrain
    Last Post: 5th July 2008, 18:40
vectra 2.0t hesitation
