Results 1 to 10 of 23
Thread: How do you clear the service reminder light
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default How do you clear the service reminder light
    Evertime I switch the ignition in my car on the service light appears (little car with spanner in front of it), the car's been serviced but the place that did it obviously haven't reset the light
    sure it's some sort of combination of holding down the reset button for the odometer and switching the ignition on/off
    can anyone help?
    sit in the car, hold down the odometer reset button and turn the ignition key to posn 2.. do not let go of the reset button until the display changes.. about 10 to 30 seconds..
    the display will then change to the reset mileage..
    Engine : Z20NET
    Thanks mate, helpful as always knew it would be something like that
    Engine : Z20NET
    Problem not solved!
    Here's what's happening:
    Everytime I put the key in to No.2 position the bit to the left where the Service light is lights up, start the car and it disapears, but surely it shouldn't be there until the car is due another service IIRC in another 20,000 miles? presumably whoever serviced it last didn't reset this thing
    So...
    If there's no key in the ignition and I hold down the odometer button the light on the left side comes up with the little picture of the car and spanner with 18,000 underneath it, I'm assuming it means one of two things
    A. That was to indicate a service was to be done at 18,000 miles
    Or
    B. 18,000 miles to my next service is due? (like a counter?)
    If I do your trick GSi 3.2, Hold down button, put key to No.2 position and continue to hold the button down, nothing happens, I still get the above everytime I turn my key to no.2 positiong
    Here's what I'm looking at
    So to summarise, everytime I turn my key to No.2 Pos that little service light on the left lights up, when you turn the car on it dissapears and if I hold the odometer button down with no keys in it lights up with 18,000 under it
    Here, there and every where!
    The car with a spanner is a fault on the car m8, needs to be read with Tech 2 to find out what it is.
    The service symbol is an oil can with the spanner
    Quote Originally Posted by Caterman View Post
    I was just thinking that!
    As above,
    what you have is a 'non-serious' redundant fault code logged on the ecu's memory..This symbol ( as long as it goes out when the car is started) just shows that some error HAS occured but the car is happy to carry on working..You could either clear them by detaching the battery for 15 mins, or leave them as it's nothing to worry about..
    I'd only take it to the dealers if there was that symbol PERMANENTLY lit when the engine was running..
    The 3.2 V6 has a 20,000 mile service schedule.. how long has it been since they serviced yours??..
    Engine : Z20NET
    It was less than 1,000 miles ago when it was last serviced mate
    It may well be on eco-service then, rather than eco-flex.. ..
    AS long as the fault light continues to blink out then i'd not worry too much at the mo..
    On some of the newer Vauxhalls this won't work. You have to press the trip reset button on the dash and also press the brake pedal as well before switching on the ignition - keep brake and trip pressed for 10 to 12 seconds - then the service interval light will be reset.
  1. service reminder
    By ian 1234 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 14:43
  2. direct gov mot reminder service
    By rjw in forum The 'Off Topic' room
    Last Post: 9th June 2011, 12:44
  3. rear light clusters clear/red/clear
    By Rickiw in forum Parts for sale
    Last Post: 30th July 2010, 15:08
  4. Service Reminder on dash on Vectra C
    By colashbury in forum Engine & Drivetrain
    Last Post: 8th July 2010, 06:00
  5. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
