Results 1 to 3 of 3
Thread: any 1 fixed a astra cdti?
    Jan 2010
    glasgow
    Default any 1 fixed a astra cdti?
    are the injectors and the pump coded to the ecu?
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    should be the same as a 1.9cdti.. pump is not coded, just a high pressure pump for the common rail but the injector flow rates are programmed into the ecu..
    Jan 2010
    glasgow
    rite here is the story i know some 1 thats got 1 now hes fited a engine the ecu has been checked and came back ok but he cant get it running it keeps throwing up crank sensor now the guys changed that still no joy and has fired easy start down it still no joy
  1. 1.9 Cdti 120 Z19DT bad starting FINALLY FIXED!!!!!!!
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 4th June 2013, 13:37
  2. 1.9 cdti cutting out randomly.... issues fixed :)
    By steve1312 in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2012, 13:32
  3. Misfire fixed 150 CDTI
    By pubcrawler in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 22:52
  4. cdti 150 turbo lag fixed
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 08:30
  5. 1.9 CDTi 120bhp hesitation FIXED :-)
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 1st October 2009, 16:00
