Can u install a sub and amp into cd70 running the RCA cables through the aux socket?
I would PM Ian Highlander, he is pretty up on car hi-fi.
Ok cheers mate
The aux socket is for input only.
You need a line out which the cd70 doesnt have. The only option is to use a speaker level input or you can get a converter that attaches to the speaker wire, but I cant remember the part name/number.
As per my PM reply to you earlier (sorry it was a bit short by the way, working at the moment). The AUX is an input only for plugging things into the stereo not to pick up a feed from for an amp.
Fit an after market head unit or use a high level to low level converter and tap off the rear speaker inputs for the amp.
Ok thanks,I just don't want to loose satnav!!
