Thread: 1.8 Petrol Revs Drop Engine Cuts Out
    Regular Member vads's Avatar
    Mar 2012
    Fife
    Default 1.8 Petrol Revs Drop Engine Cuts Out
    Help!!!
    2002 Vectra 1.8 LS (Petrol) 87k miles
    I left for work this morning and started to have problems, it's only a 10 min drive but from the very point of leaving the house i noticed i had a problem...
    When the cars in neutral the revs drop off right down till the engine cuts out, I could see it happening and attempted to rev a little but it seemed to lag sometimes and bounce back. If i was stationary at a junction the engine would just die and need to be restarted.
    Could anyone point me in the right direction for a fix?
    Jan 2012
    Gloucestershire
    I used to have a 2000 1.8 16v Astra and the only problem I had with it in the 4 years I owned it was idle stability. All I used to do was remove the air inlet to the throttle housing and give the throttle housing a good clean with carb cleaner and a rag on the end of a screwdriver. This always fixed my idle issues, although ideally I would have removed it, cleaned it up properly and replaced gaskets as necessary.
    I think there are a few designs of throttle housing/idle valves though, so maybe someone else can help more.
    Good luck.
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    sounds like maf or icv common symptoms
    more maf if its struggling to pick up the revs
    Mar 2012
    Fife
    Thanks guys, comments appreciated but its getting worse ...
    Update:
    Garage had a look at the car today and phoned me at 1pm to say it was sorted (throttle housing needed a clean as DieselWig said)
    I asked garage to give it a service fuel, filters, oil & plugs, 5pm they call me to say its not ready for collection as the engines running lumpy and it wont rev.
    Any ideas what the next step could be? reading forums i'm hoping its not a blocked cat :s
    scotland
    coil pack
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    I know its not the same manufacturer but my Fiesta (sorry for swearing) started to do this - the first problem was it blew a plug out of the head, complete with the thread from the head, this lead to the head having to be replaced by the new owner.
    Dont mean to panic you but the symptoms seem very similar - revs dropping when at junctions / on idle to the point of cutting out and running lumpy - Fiesta was on 3 cylinders as the 4th plug was on top of head.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Sounds like the MAF too me too, might be worth giving the sensor a spray with contact cleaner and see if that helps. Has the EML light on the dash come on?
    Mar 2012
    Kent
    Its most probably the Cat
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    We had 51 Astra VVT that had the idle problems - fixed by cleaning the throttle. Another two incidents were due to 1) loose connection on the temp. sensor 2) Kwikfit fitter left the exhaust sensor wire off.
    I would say garage has disturbed a sensor wire /connector of some sort.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by gsxrster View Post
    coil pack
    I would be more inclinded to think about a duff coilpack as well before replacing more expensive components.
  1. Replies: 0
    Last Post: 3rd February 2013, 13:54
  2. revs drop too 500 then rise back to 800ish
    By Mickyboy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 14:34
  3. Revs slow to drop
    By bazsignum in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2009, 07:59
  4. Replies: 3
    Last Post: 6th July 2009, 11:04
  5. 2.2DTI - Revs drop and engine cuts out
    By altheman2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2008, 20:55
vectra c 1.8 cutting out without revs
vauxhall vectra drops revs and cuts out
vectra cutting out petrol
vectra revs drop when idle
vectra c 1.8vvt i still not running properly after changing coil pack
vectra c drops revs and cuts out on startup
vectra c cut out coil pack
zafira 1.8 2003 cut out problems
