Thread: ive got a rattler
    Regular Member ilvpie2.2's Avatar
    Apr 2012
    Tenbury Wells
    Trim : Exclusive
    Engine : 1.9cdti
    Mileage : 50000
    Question ive got a rattler
    hello everyone, ive just bought a 2.2dti and when its started from cold its beutifully quiet, but after a couple of mins it starts to make a kind of rattly noise. ive had a good look round and cant see anything loose but when i took the drivers front wheel off and looked at the belt when running it appears to loosen. dont know if this is any way related but when the lights are on at night they dim slighty.is it possibly an alternater problem or am i barking up the wrong tree. hoping for a cheap solution (arent we all!) forgot to mention when its reved it stops the noise.
    East Ayrshire
    Trim : SRI XP1
    It could possibly be knackered bearings in alternator, knackered tensioner or maybe the belt is just knackered, but I doubt that would cause a rattling
    Regular Member coooky's Avatar
    May 2011
    washington
    or could be the same problem i have sounds awful and its the drive belt tensioner for the alternator and it has knackered a 3 month old alternator so i would check that out asap as you dont want to be pulling out for an alternator as well
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    have you tried putting in the clutch to hear if it makes a difference possiblie a flywheel rattle
    Apr 2012
    Tenbury Wells
    Trim : Exclusive
    Engine : 1.9cdti
    Mileage : 50000
    hi thanks for the suggestion ive tried the clutch theory but it makes no difference. cheers anyway.
    Regular Member gsi-robster's Avatar
    Mar 2012
    paisley
    maybey have a clutch type pulley fitted to alternator?
    these can rattle and slip
