Results 1 to 10 of 15
Thread: fitting an ncdc 2013 and gid
    Default fitting an ncdc 2013 and gid
    ok here goes
    my ncdc 2013 and gid arrived today ( thank you stephen )
    ive ordered the aerial from ebay for the sat nav and will be ordering a sat nav cd when i can find one !!! ( if anyone has a cd they no longer need please pm me )
    right what i want to know is what part of this how 2
    http://www.vectra-c.com/forum/showthread.php?t=94808
    do i have to do , kenp has already said that i dont need to do part 4 as i already have a gid fitted in my car so the 32 pin plug is already there , i just need to know if there is any other wiring i need to add
    not the best when it comes to electrical stuff
    any help will be much appreciated
    sorry to whatever mod had to move it lol
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes you need to add/change the other wires as described.
    thanks for replying kenp , im still not getting it
    as i dont have a colour screen to fit i take it i dont need the 12 pin plug because theres nowhere for it to go
    also do you really need an sot lead , if you dont that would remove steps 1 to 5
    so that just leaves adding the extra 5 wires from number 6 to number 8
    am i correct or have i missed sometheng
    oh and whats an EEC ?
    Engine : 2.2 Direct
    No you dont need a SOT lead.. but then you have to change the wiring in the plug.. where you can make the sot-lead so its plugin wiring..
    but no matter what you have to do wiring work.
    ECC = Electronik Climate Control
    and funny most og your questions would be better in the discussion for the how2
    i think ill continue this in the how 2 discussion , but when you said about the sot being a plug in, a light bulb went off in my head and it all became clear
    basically if you do the wiring on the sot and then connect them to the 32 pin plug and eec and diag port it saves cutting the harness in the car and makes it a lot easier to do
    just got to find the right sot lead now
    i appreciate the help youve given me kenp
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Watching this thread as I already have the GID and might upgrade to the NCDC 2013 at some point too. The original thread is a wee bit complex and confusing to me too.
    Mark take pics of just what you added wires wise when you do this please.
    milton keynes
    basically if you have a GID and want to upgrade to a NCDC with matching GID you need to add 2 wires to get it to function , if you have standard air con that is. These 2 wires go between headunit and display.
    ISO-block pin 33 to GID pin 19
    ISO-block pin 32 to GID pin 20
    Kman I'm quite sure mine has climate control , if I do is it just the 5 wires I need to do
    Sent from my iPhone using My thumb
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yes u are correct mark it's and easy job mate
  1. ncdc 2013 sat nav, help
    By bigbrox in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 07:24
  2. Ncdc 2013
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2010, 00:05
  3. Ncdc 2013 Help
    By mickeystitch in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2007, 18:12
  4. ncdc 2013
    By ally1873 in forum Troubleshooting
    Last Post: 6th February 2007, 14:31
which car is the vdo ncdc 2013 fitted in
