Thread: Side indicator repeaters
    Jan 2006
    Hertfordshire
    Default Side indicator repeaters
    Hi all,
    have ordered the clear repeaters to replace the orange ones.Has anyone on here done this mod,i.e. do they just prise off and do the bulbs
    need to be changed for orange ones.
    Thanks in advance.
    Colin
    Regular Member Harry's Avatar
    Uxbridge, London
    you need to push them towards or away from the front wheel, can't remember now. i changed mine to the crystal clear ones from LMF, are these the units you got?
    these ones came with the orange bulbs - 15 quid if i remember correctly
    do a quick site search and i'm sure something will turn up
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Hi, i removed my clear repeaters to tint them black,
    I lifted the vertical side of the repeater nearest the door away from the panel then inserted a small screwdriver to push the internal locating clip towards the front of the car and the repeater pops out!
    I covered my screwdrivers with electrical tape in case i slipped.
    Oh and before you remove the plug from the repeater, tie a piece of string or tape to it as it may fall back inside the wing!
    Thats how i did mine, it may not be the best way!
    Woodsta
    Jan 2006
    Hertfordshire
    Thanks for the replies,clear useful info as always on here.Yes Harry,got them from LMF.Woodsta,will keep in mind what you said.Appreciate yor help,thank you.
    Colin
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    those smoked side repeaters look good
    Feb 2007
    Wales
    Thanks for this help guys - one of my side repeaters had stopped working - turns out the bulb cable had dropped down into the wing - with the use of an old coat hanger (bent at some odd angles), I was able to "fish" the cable out and get the light working again...but without your help I could not even get the repeater lense off the car...!!! THANKS AGAIN
  1. Side repeaters
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2011, 22:12
  2. side repeaters
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2009, 21:42
  3. Side Repeaters Help Please
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 18:19
  4. Side repeaters
    By Merick in forum Styling
    Last Post: 28th April 2007, 15:02
