Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: boost pressure sensor input and output voltage???
    Jun 2011
    Herts
    Default boost pressure sensor input and output voltage???
    hi folks.
    I've been having issues with the beast (2.0dti) and plasma stuck his tech2 on it for me(gentleman that he is)and it brought up the code for the boost actuator valve......
    having swapped it over with a coul[pe of others I now dont think the problem lies their....... and I think the problem may be with the boost sensor(MAP) that tells the ecu what to do with the actuator to regulate boost.........
    I've seen the how to test a MAP sensor video:
    http://vectra-c.com/forum/showpost.p...0&postcount=32
    and this one:
    [ame="http://www.youtube.com/watch?v=_vAtjLil5Y0&feature=fvwrel"]MAP Sensor & Wiring Diagram - YouTube[/ame]
    and am slightly confused as according to the leaflet form bosch the sensor output to ecu should start at about 1.5v on idle and increase up to a max of about 4.5v under maximum boost...... which sounds the opposite of what the tech on the video says.... or am I confusing pressue and vaccum??
    having watched the video and (back pinned/paperclip) tested the MAP sensor, I know that it is getting 5 volts in (as expected) but sending 1.6v out to the ecu(rather than th 5 in the video)whether the ignition is just turned on (2nd click) or the car is on and idling(like a ffffiinf tractor BTW)..... and when i did the suction test with the just ignition on- (using hose and lung method as i don't have a vac gauge) the voltage drops from 1.6v to 1.3v
    so the qusetion is- can anyone tell me what the in and out voltage is on their (good) diesel MAP with the ignition just turned to the second click and then when the engine is started????
    or are there any clever folks who know the answer without having to test anything??? lol
    any help greatly appreciated :-)
    Jun 2011
    Herts
    bump......................
    and when I start the car and rev it to 2750 rpm the volts drop from 1.58v to 1.44v
    car won't rev past that as the turbo isn't kicking in.......
    does it sound like a boost sensor issue??? al boost hoses are ok but the Turbo Wastegate Actuator Valve isn't getting a SWITCHING signal....
    experts please step forward and show your intelligence....
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Flob can you confirm the part no,s of your maf and boost sensor , i may be able to help you out
    Jun 2011
    Herts
    Quote Originally Posted by bobssignum View Post
    hi BOB, it is (and this is stuck in my head lol) 0281 002 437 I think it is the same part on all the diesels except the V6
    any help would be greatly appreciated.
    cheers
    Steven
    oops jst saw the MAF bit- will get the number and volt reading now - sorry fella
    Engine : 2.0DTi
    Mileage : 73350
    Right i have a second one here plus i also have a maf part no 2443 7503 which also came off my DTi . now provisionally me and khalid are going to dean,s plasma,s on sat morning .
    If you can make it there then we should be able to sort you out, or if not we can make it somewhere on route.
    Engine : 2.0DTi
    Mileage : 73350
    steven also have a look at this thread
    http://www.vectra-c.com/forum/showth...ighlight=p0243
    Jun 2011
    Herts
    satuday morning sounds great to me..
    my maf is BOSCH PART NO 0281 002 479 which from a quick search matches your vx part number
    the maf is reading: battery voltage @ pin 2
    0.6v (+/-0.2) @ pin 3
    2v at ignition click 2, 5v when at idle and still 5v when revved to 2750rpm @ pin 4
    1.9v a click 2 and at idle, and 2.9 volts when revved to 2750rpm at pin 5
    not found any spec for the maf yet so can't really from an opinion...... not that I know much lol
    Also my boost pipes seem to be ok but I'm replacing them with silicone this avo as it only cost s7 quid...
    the exhaust smells diesely and is chuffing out a lot of smog under revs....... but the wastegate pulls closed when the car is started..... just seems something is not telling the wastegate what to do I think, ish :-/
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Maf should be 1.5 idle I'm sure.
    Will see if can find full set of true expected readings on tis later
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I've pmd you but will post here too incase it helps someone else.
    Check egr is fully sealing as a partially open egr can kill boost pressure.
    A map sensor an throttle position sensor should read same at wide open throttle.
    So of you can get live data an compare.
    And I believe map sensor should be around 1.2v @ idle
    Here are some readings I took from my v6 cdti, Car was warm after just completing a few mile drive and has 128k on clock and suffers a slightly un even idle every now an then.
    So granted not perfect for testing against but gives a rough idea
    Maf = 1.6v @ idle 3.3v @ 3000rpm
    Map = 2v @ idle 2.8v @ 3000rpm
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    No Vauxhall techs that might be able to offer some help/ advise for him?
  1. boost pressure sensor
    By iwtand in forum Engine & Drivetrain
    Last Post: 5th February 2012, 20:43
  2. 2.0 dti boost pressure sensor
    By jono m in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 12:08
  3. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
  4. MAFlow Voltage output.. Help
    By Imi in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:51
  5. Boost Pressure Sensor
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 12:52
not getting 5volts to maf zafira dti
what should the reading for a boost pressure sensor on a vectra
maf voltage chart Corsa c
map sensor idle vectra
