Thread: rain/headlight sensor
    North Tyneside
    Default rain/headlight sensor
    When it is raining and I have the wipers on in either intermittent or continuous mode the headlights now don't come on. It would seem to be a faulty sensor. Is this the case and is it easily replaced, any idea how much a new sensor is? Any advice would be appreciated, Thanks.
    The headlights don't come on with the wipers, or am I not understanding your question correctly?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Depends on how fast them wipers are working. Sometimes mine (lights that is) don't come on unless it's really chucking it down and quite overcast.
    North Tyneside
    I've an 06 Design spec and the wipers have always actuated the headlights after a period of time, usually only a few minutes. I was on the A1 yesterday and it was raining heavily and the headlights simply didn't come on and I had to switch them on manually. I gave them a good ten minutes and previously they have come on after a lot less time than that hence my assumption that the sensor is faulty. They come on with no problem if it is overcast or if you go into a multi storey car park so the light sensor seems to be OK.
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    The way to test it is to start the engine, put the lights into Auto and then cover the sensor at the top middle of the windscreen, to test the wipers put them into the auto mode (one position up) and poor some water down the screen.
    If the wipers are working from the speed adjuster then chances are your sensor has gone.
    Regular Member lutonmatt's Avatar
    Feb 2012
    kent
    i had this monday the lights would not come on when it was raining
    but then was not very dark
    I thought it was two separate sensors.
    One for the lights, one for the wipers.
    Hence my earlier comment of the lights shouldn't come on when you switch the wipers on, unless it's dark enough or overcast enough for the light sensor to switch them on.
  1. rain sensor
    By n8sby in forum Parts for sale
    Last Post: 22nd May 2010, 16:56
  2. Rain Sensor
    By suj786 in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2005, 18:30
