Thread: aircon help
    Regular Member jimmywhu's Avatar
    Sep 2011
    essex
    Default aircon help
    think my ac has gone when i put it on the fan goes to 7 and no real coldness i have felt also the light does not go on the button but when i put the residue ac on after car shut down light works confuesd . com
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you have climate control?
    11 Post(s)
    With 7 speeds - most probably.
    Putting it on the highest speed will probably not allow the system to get cold enough (i.e. you're taking more out than it can give, especially if the system is a few years old).
    What is it like if you use a lower speed setting?
    Barrow In Furness, Cumbria
    If the light on the button isn't working then its probably fuse / electrical related.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Chris SRi View Post
    ... unless the Vectra does the same as the Senator and Omega did... when the low pressure cutout prevented the system working (due to a gas leak) you could press the button as much as you liked yet the AC wouldn't come on and neither would it's light.
    Smart move would be to check the fuses first, but my money would lean toward the old favourite - leaking condenser. Residual AC isn't actually aircon as the engine and therefore compressor isn't running.... it's merely a 'permitted run-on'.
    No, it doesn't. My A/C didn't work when I got it cos it was low on refridgerant but the light came on.
    Apr 2012
    portsmouth
    Can you tell me how to get the residual a/c feature ?, i have climate control in my 55 plate vectra cdti design and cant find anything about it using google
    11 Post(s)
    Quote Originally Posted by trimble View Post
    Ignition off, and press the auto button. Radio display will then show "residual AC on", or something like that.
    Apr 2012
    portsmouth
    Mine must be different as auto is on the right fan speed selector knob and i just turn the knob to auto and set the temperature on the main big dial in the center
    11 Post(s)
    Ah!! you've got the automatic AC system, not electronic climate control; which is something half way in between the bog standard AC, and climate control.
    Only the climate control has the residual AC feature.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Aircon
    By GoldenWonder in forum Bodywork & Interior
    Last Post: 20th June 2012, 18:18
  3. aircon
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 13:32
  4. Aircon
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 27th November 2008, 19:04
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
