Results 1 to 10 of 14
Thread: Tyre wear causes?
    Regular Member weverall's Avatar
    Littleport, Ely, Cambs
    Default Tyre wear causes?
    Attachment 53874
    What would cause this wear on the passenger side rear wheel?
    It's only happened on this side and the other is ok?
    Barrow In Furness, Cumbria
    Looks like a suspension component is badly out of alignment!
    Unless its been rubbing on something?
    That tyre looks like a Michelin Pilot Sport 3
    What size is it?
    The rear of the Vectra C is known for having incorrect camber
    If the tyre has been on the rear for all of its life, and the camber has never been checked / adjusted, then I am not surprised by that level of wear
    Obviously this tyre has to be replaced NOW
    Equally, I would replace the offside rear as well
    On completion have a full four wheel alignment carried out
    Prior to this the suspension and steering should be checked for play and worn parts, these need to be replaced BEFORE the alignment is carried out
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Looks like the banana arms may have play in the bushes.
    As above, get all the joints and bushes checked for wear, then full alignment
    Aug 2010
    Leeds
    From new mine was way out vauxhall did it under warranty they showed me the print out.
    Have it checked 4 wheel laser alignment but do check bushes as said above good advice.
    So im gunna follow all this ideas thanks guys
    as for new tyres... these are 19 Snowflakes... so whats the best tyres to go for? i heard something about Neo Bro's but i have no idea on tyre size i would need at all?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    235/35/19 is what you need fella. Neos sell the Neuton tyres which are cheap and very good in the dry but a little skittish in the wet. Got them on mine.
    Brilliant man, will give them a ring later to see what they have
    So they have what I need
    And went into town and asked about tyres, and they recommended 107+vat for Maxxis ones?
    Any suggestions on what to go for?
  1. tyre wear
    By fjaimo10 in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2011, 21:43
  2. tyre wear
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 20:08
  3. Tyre wear!!!!!
    By glenboy in forum Handling & Braking
    Last Post: 26th October 2009, 19:20
  4. Tyre wear
    By fishphone in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2009, 19:09
  5. M.O.T And Tyre wear.
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2008, 20:44
