Results 1 to 10 of 28
Thread: inlet change?
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    Angry inlet change?
    good evening everyone
    i have read through quite alot of threads about the swirl flaps on the inlet and seems to be a common problem in the 1.9 cdti. after having my new signum serviced today after owning it for two weeks they cam up with expensive advisorys. DMF and clutch, cam belt/ water pump, and the inlet. according to them 2k worth or work .
    the operating link has fallen off the ball joints and sitting inbetween the inlet and the block. can i not take the operating link off a an 07 engine and fit it to mine instead of changing the whole manifold. the position of all the flaps are different no.1 is facing 8, 2 is towards 9, 3 is at 10, and 4 is at 5. im sure this will make the engine suffer.
    if the inlet needs changing how difficult is it to do it yourself?
    Alec
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Apr 2012
    littleport
    tony
    yours is the one i read the most of. did you rotate the flaps from the ball joints from the top?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I removed the bar, set flaps 1,2,4 at the open (10 o'clock) position, then applied some strong heat-resistant glue around and over them (don't be shy about using loads of glue!!). Left the car for 24 hours for the glue to set. That was about 10k miles ago, and they're still solid now, and it runs like new still.
    Leave #3, as the motor needs to move it, otherwise a fault will show up.
    Apr 2012
    littleport
    sweet will do. aradite ok? :P
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by smartalec0310 View Post
    I used Evostick from B&Q. Plenty of it too
    http://www.accesstoretail.com/upload...100917_250.jpg
    My inlet is the original on the car. Done 138k miles now
    Apr 2012
    littleport
    lol silicon my dads a tiler so have plenty of it but i suppose it needs to be heat resistant
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I wouldn't use silicon. It doesn't set rock solid, and will come off over time
    Apr 2012
    littleport
    right ok ill get some of that stuff and save myself about 1k lol gotta change a rear spring to which is easy
  1. inlet change f**k up!!!!!!!!!!
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 23:15
  2. Inlet manifold change
    By LGaffer in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 15:38
  3. Inlet change tomorrow
    Last Post: 2nd February 2013, 17:44
  4. Well finished the inlet manifold change
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 22:18
  5. Is there a written how 2 for 1.9 cdti inlet change?
    Last Post: 18th December 2012, 00:59
