Thread: Key Fob Battery Changed
    Tayside
    Default Key Fob Battery Changed
    Hi,
    I have changed the battery on my key fob. I then went to sync it with the car but im having some problems. The handbook says to put the key in the driver's door and turn to the front of the car and then return it to the vertical position and use the key fob to unlock the car. When I turn the key inside the lock and then press the button nothing happens. When I then open the driver's door the alarm just goes off.
    If anyone can help that would be great. I hope ive not de-activated the key some how
    Chris
    i thought you put it in the ignition , turn the ignition lights on then press unlock button
    Tayside
    I got it working now thanks. I just turned the key in the door to open the driver's side, opened the door which did set the alarm off but I just put the key in the ignition and switched it on. I tested a couple of times that I could lock and then unlock the car with the remote and it seems fine.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Any time you unlock the car with the key the alarm will go off. Mine always does it.
    3.2 v6 Signum and loving it
    11 Post(s)
    Quote Originally Posted by Johnsdutton View Post
    Not until you open the drivers door.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Ok Dave, I missed that wee bit out to see if you were alert,
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  3. Park Pilot stopped working after I changed my Car Battery?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 5th August 2011, 17:06
  4. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  5. Changed the battery now no radio code
    By neilb1 in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2011, 02:14
vectra c key fob battery
