Thread: B2961 dtc code
    Aug 2011
    selsey
    Default B2961 dtc code
    Hi
    apologies if this is not the correct sub cat for this. Recently had to replace the EGR valve
    replaced EGR valve and after that sweet as, low down power returned.
    So, yesterday (9th April 2012) drove the car in the morning everything normal. Went to drive the car in the evening and its all of a sudden got the following fault
    When i put the key in the ignition and try to start the car its dead although the dash lights up like santas tree, WTF!!!
    If i keep turning the key and hold it in the crank position after a while it suddenly turns the engine over and starts.
    The diagnostics reader found the following fault code
    B2961 position ignition key switch circuit malfunction
    Any body have any idea what causes this mysterious and sudden appearance of the error, or even what it means? It seems to complain about the key in the ignition, well what else would i do with it
    Aug 2011
    selsey
    Something else I have noticed is that when the car finally starts and drives, the central locking no longer automatically locks grrrr
    Aug 2011
    selsey
    If anyone is interested, I seem to have solved it and if it is as easy as it seemed I'm surprised.
    I have basically replaced the CR2032 battery in each key and all seems fine, weird huh!
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Hmm, see how it goes, when I got my car it had two keys one of which didnt have a battery in it but both worked fine (except you couldnt turn the alarm off), it could be just electrical gremlins.
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Did changing the key battery cure the problem for good Pezzar? I have the same code and non starting problems.
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. Ecu code
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2011, 17:45
  3. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  4. code Key
    By mcints77 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 15:09
  5. Key Code
    By HB39AA in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 15:50
b2961 key in ignition circuit malfunction
Vauxhall DTC B2961-08
Opel DTC B2961-2
Opel B2961
Opel B2961-C
b2961-08 opel
opel corsa faulty codes B2961
Vauxhall B2961
vauxhall combo fault code B2961
b2961 corsa
opel corsa c b2961
2961 DTC assault
Corsa utility fault codes b2961-2
b2961 opel tigra
fault code B2961-2
b2961 key egnetion circuit .
Vauxhall DTC B2961-2
vauxhall combo 1.3 cdti fault code B2961
GM DTC B2961
b2961 terminal w low voltage how to solve
Opel DTC B2961-08
foutcode b2961
b2961 fault code
problem b2961 opel corsa
corsa c b2961
