Results 1 to 2 of 2
Thread: confused .com????
    Regular Member Gerdo3's Avatar
    Blantyre
    Default confused .com????
    can someone advise me which of the 2 tasks should be done first
    1. clean and blank egr valve, or clean and use fiat gasket?
    2. can of carb cleaner in through the air intake?
    bit of confusion as some members in the various forums say that if you do the carb cleaner first you fire more crap into the egr valve, or do i clean the egr first without blanking off until i have run carb cleaner through??
    thanks
    G
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    I would avoid the carb cleaner in the intake.....
    Spend an hour removing the EGR and TB then clean the lot along with inside the inlet manifold. Big spoon and cloth on a stick works great. Blank or fit fiat after the clean.
    Spraying carb cleaner in the intake only helps up to the intake manifold as nothing after that is cleaned by the carb cleaner as burnt up in the piston chamber.
  1. Confused!!!
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 15:53
  2. How confused am i
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:36
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused About Car Key
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 22:54
