Results 1 to 10 of 13
Thread: condenstation in fog light
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default condenstation in fog light
    I seem to remember reading a tip on how to stop the condensation build up in the front passenger side fog light
    Can anyone point me in the right direction as I currently have the front bumper off the car after just fitting my Signum fog surrounds
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    the little silicon packs you get in new shoes. There is a snorkle you can fit, but aparently it doesnt work
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Yes it does
    I have one post mod fog, one pre. The pre mod / non snorkel one is always fogged
    Nov 2009
    south wales
    What is the snorkel mod? I was thinking of a small hole drilled underneath the light would let any moisture out?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Right a little trick to employ ,firstly pick a dry day , remove the cover from the botom of the light then drive around as normal with the fog/driving lights on .
    Once all the condensation has been removed then place the silicon bag in the light and refit cover .
    This will work 98% of the time the only way it wont work is if you have to much water in the lights for the heat to evaporate .
    and still loving it
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    i had same problem,took the spot out of the bumper dried it out ran a bead of silicone sealer round the joint between the glass and the rear housing never had any problem since,did the other while i was at it as the seal on that one looked dodgy as well
    Nov 2009
    south wales
    Quote Originally Posted by bobssignum View Post
    Mmmm. where me gonna find a little bag of silicone?
    The Mrs has thousands of shoe boxes up the attick. Best start there
    Feb 2011
    Selby
    Another thing that helps a lot is - when you fill the screenwash bottle, use a funnel so you don't pour it all over the top of the foglight...
    Dec 2011
    Seaham
    At the moment, I think your biggest problem will be finding a dry day?
    Quote Originally Posted by larrysSRI View Post
    What is the snorkel mod??
    Search box found it straight away:- http://www.vectra-c.com/forum/showthread.php?t=47934
    Been there, done that. Ended up with a fog light full of water when I went through a deep puddle and the water splashed up in through the hole.
    Melted hole back together with a soldering iron and fitted a pack of dessicant (moisture absorber) and hasn't misted up since (providing I remember to change it yearly)
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
