Thread: 56 Reg 2.2 Direct won't start
    Mar 2011
    london
    Default 56 Reg 2.2 Direct won't start
    Hi, long time lurker here
    Left my lights on and stuck with a falt battery. Radio still works. Jumper start didn't work and initially there was some clunking noise, local (non vauxhall) garage guy is sure it is an engine problem. Decided to get to a proper vauxhall place later. Just wanted to know if he is correct?
    Since then the central locks don't work and each time I try to start the engine the immoboliser/electric fault light blinks, pedals feels stiff. I still think its related to the battery and somehow jump starting attempts have messed up with the ecu/emu? Can I somehow fix this by putting in a new battery?
    Zul
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    It does sound like a battery problem fella. Try recharging your battery or a new one. Thing is with jump starting there is always a risk of spiking a ecu or something. Where they heavy duty jump leads that you used?
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Open ya car with ya key so the alarm goes of then turn the ignition to position 2 don't start turn it off again ya central locking should work on the fob lock the car the unlock then try start it
    Mar 2011
    london
    Chris: I had a guy come in with his van, used two different battery boosters and his special jumper cables to his van.. he was quite sure that it was the timing chain as it rattled the first time he tried to start it. The engine was sort of cranking but not really starting (not sure how elso to describe it)
    Paul: will try that in a bit
    Mar 2011
    london
    Would the ECU reset itself with a new battery?
    Mar 2011
    london
    new battery in and still not starting.. its making a sound like its about to start but not quite firing up.. not sure how else to describe it. porbably time to go to a vx garage
    Nov 2011
    Cheshire
    Vehicle : 1.9CDTi(120)SRi
    Engine : 1.9DT
    Mileage : 100k
    Something smells fishy to me, a flat battery wouldnt cause a snapped timing chain! It does sound like something electronic has been knocked out of whack, im wondering if the guy with the van connected the jumper cables the wrong way.
    It needs plugging into a laptop to see whats going on.
    Mar 2011
    london
    [ame="http://www.youtube.com/watch?v=_LJDT-7zWmU&feature=youtube_gdata_player"]Vectra z22se not starting - YouTube[/ame]
    It sounds similar to this engine. Left the battery disconnected today. Will check on it later. Will only be able to bring it to VX garage tomorrow (Now at Richmond)
  1. 2.2 direct sri wont start!!
    By stephen2480 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2012, 10:56
  2. 2.2 Direct Rough Engine Noise on start up
    By Jonnie C in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 19:04
  3. Vectra 2.2 direct petrol 2005 will not start
    By bakercbak in forum Engine & Drivetrain
    Last Post: 8th October 2011, 15:05
  4. 2.2 direct wont start
    By gordy07 in forum Engine & Drivetrain
    Last Post: 22nd December 2010, 14:33
  5. 2.2 Direct warm engine start
    By Sambor in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:12
