Thread: UEC Fuse box numbers 12,13 and 14.....
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default UEC Fuse box numbers 12,13 and 14.....
    Can someone tell me what these are on the facelift and pre-facelift Vecs?
    With the fuse rating too please
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Preface.
    12 Windscreen wiper 30 A
    13 Central control unit, TC, ESP 7.5 A
    14 Headlight wash system 30 A
    Facelift.
    12 Central control unit, ESP®Plus 7.5 A
    13 Headlight wash system 30 A
    14 Oxygen sensor 10 A
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    That'll be why i've just popped a 7.5 amp fuse
    I was having problems with the headlight washers bud and looked at my hand book and according to it the fuses were in the wrong place.
    It turned out the connector was needing a clean and when I cleaned it I pulled the washer stalk and the headlight washers worked for a second and then stopped. The 7.5 amp fuse was blown
    My facelift hand book is wrong and shows the pre-face fuse arrangement.
    The book is dated August 2005 and has a facelift on the cover
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    LoL, yea when I swapped the UEC I had the same issue. The UEC I gave Phil is a full canbus one and has the washers fuse in 13. Grab that facelift manual I left at phils next time your down mate. Your is an 07 is it not?
    Heres the online facelift manual. PM me your email addy and ill send you a preface pdf.
    https://www.vauxhallproductforum.co....icles/2217.pdf
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It's an 06 mate so they either made a mistake with the facelift manuals or the first of the facelifts had the old configuration.
    Couldn't figure out what the hell was wrong as when I bridges the connectors at the pump and tested where the relay plugs in I was getting a complete circuit
    Everything works sweet now bud.
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. fuse numbers for 54 vectra??
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2009, 14:40
  4. Fuse Numbers
    By BlueRob in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2008, 17:43
  5. car kit fuse
    By daveg8843 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2007, 22:58
vectra c uec fuses
vectra c face-lift uec fuses
