Page 1 of 8 123 ... LastLast
Results 1 to 10 of 80
Thread: Signum turbo lambda sensor problem
    Apr 2012
    Doncaster
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    Angry Signum turbo lambda sensor problem
    Today, 17:54 * #1
    Rasher
    Feedback Score: 0 reviews
    2.0 T signum lambda woes
    hi i recently bought my signum 2.0t. when driving the car home i noticed the engine management light was on and car was under powered.
    when i got back home i plugged the car into my laptop and it came up with the code
    P0134 02 sensor circuit no activity detected (bank 1 Sensor 1)
    i then lifted the bonnet to find that the lambda has been connected to the car simply by twisting the wires together and without a proper plug. i retwisted the wires together for now, cleared the code.
    Car still felt underpowered so thought sensor must be shot.
    while on my way to get a new sensor car sprang into life and had a turbo again. it had never had that sort of power since i first drove it. checked the codes and none present.
    next day car felt underpowered checked the codes again same code but this time a pending code. so cleared it again.
    Today the eml light has came back on again so checked codes again and this time
    P0134 02 sensor circuit no activity detected Bank 1 sensor 1
    P0138 02 sensor circuit high voltage Bank 1 sensor 2
    the previous owner says that sensor 2 has already replaced but i dont have a receipt for this.
    looking at the live data
    sensor 1 when actually working is running between 0 and 0.8v
    sensor 2 is running 0.1 and 1.025v
    so do you wonderful people think the twisted wires r at fault for sensor 1 inactivity or the actual sensor as wiring hasnt been disturbed and all connections are taped separately so as not to short. and because the sensors not running correctly this is causeing sensor 2 to run at high voltage to compensate for the inactivity of sensor 1
    thanks in advance for you comments
    cheers chris
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    Just thought id post in the engine section as well as electrical just in case i had posted wrongly sure admin will delete as appropriate cheers
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Even if their not the fault their not doing any good so need to get it sorted.
    You can confirm if sensor is running ok, be creating and air leak should affectbthe voltage
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    Ill try that. When sensor 1 decided it was working car ran great but its now thrown up again and got the extra code about sensor 2 now which seems to have a large difference to sensor ones operating range.
    Will normal thru crimps b ok for the lambda wiring or cause issues with resistance or something?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    How I no it is therearone should be pretty much constant as it just confirms that cat is doing it's job.
    And front one should be switching
    The connectors should be ok yes
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    Cheers ill get connections sorted tomorrow and have a look at rear sensor voltages again.
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    thanks for your help so far guys, sensor 1 no longer throws up a fault code and seems to operate between 0.1 and 1 volt as it should. although now
    sensor 2 is throwing a fault code up saying voltage too high meaning mixture is to rich. sensor 2 has been recently changed by previous owner all though i have no paperwork to prove.
    could this be a dodgy maf making car run too rich sensor one alternating rich to lean as much as it can and sensor 2 still saying its to rich even if sensor one is working correctly. cheers
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    Bump
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    could be the maf but equally could be the sensor itself, could be a cheap nasty one or just coked up.. I cleaned mine up by jacking the car up, unscrewing the sensor from the exhaust and dangling the end in vinegar overnight..
    Apr 2012
    Doncaster
    Trim : Sri
    Engine : Z30dt
    Mileage : 104000
    While the first sensor was showing no activity the second didnt throw a fault up. But no the first is working properly its saying mixture is to rich. Which is why i suspect maf is causing car to run to rich beyond what sensor can do to adjust. Lad i know pluggibg tech 2 in tomoz hopefully. Will this tell me for definate whats happening.
    Does anybody know the correct values the maf should b showing etc. really want to get to the bottom of this as car is great when its not got fault code. Cheers
  1. Lambda Sensor
    By Sambor in forum Engine & Drivetrain
    Last Post: 14th June 2010, 19:43
  2. lambda sensor problem
    By dan1983 in forum Engine & Drivetrain
    Last Post: 2nd February 2010, 12:50
  3. Lambda Sensor
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 16:27
  4. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
z20net p0134
