Results 1 to 10 of 16
Thread: Strange smell
    New Member Andyjarvis's Avatar
    Mar 2012
    South Moreton
    Default Strange smell
    I was behind a 58 plate Vectra 1.9CDTi Estate, it's exhaust was a little smokey and the fumes smelt like it was burning Parafin, certainly not the smell you'd expect from a modern Deisel, any ideas.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    poss dual fuel
    running on gas
    Oct 2007
    west yorkhire
    Could have been doing a DPF regen.
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Maybe doing a regen of the DPF.
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    Diesel Partical Filter regeneration in process my signum does it and it has the same smell ! Its normal
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    i havent bought Parafin for a while ive forgot what it smells like
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 128000
    i found this off another post
    I need more info on this because i'm getting fed up looking like the red arrows are following me to work every day.
    After twenty minutes driving on the motorway my 1.9 CDTi starts smoking, what i would call white smoke.
    Now i normally switch the ignition off and on while coasting and it disapears, but thinking its just self cleaning and as i was just about at work i took it easy and left it smoking for ten minutes.
    during this time i tried all revs up to 3500rpm but no change just really bad white smoke which smells like parafin and the gas is hot and i mean hot.
    As soon as i switched off and re-started it nothing.
    i just wondered wether it was still cleaning or wether the DPF had been removed so the ECU was not getting the intended signals.
    The car has done 153,000 miles and it has done the same thing since i bought it two years ago.
    I am thinking the DPF may be blocked and removing it may be the answer.
    Thanks for the heads up on this and any help that may come from you guys will be very welcome.
    Mar 2012
    South Moreton
    I should mention this was in 40mph limit which is why I didn't think DPF Regen.
    Mar 2012
    South Moreton
    Quote Originally Posted by vectra ste View Post
    I have mates who play with Parafin heaters, sorry, I mean Gas Turbine model jets so the smell of buring parafin is quite familier.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Perhaps hes running it on parafin - I used to run my old Astra 1.7 TD on Kerosene and then cooking oil and it stunk of chips - ran ok though
  1. vectra 2.0 turbo strange strong smell from exhausts
    By matrix1979 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 18:13
  2. strange smell ..
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 11:50
  3. Spanner Light and strange smell!!
    By neil1194 in forum Engine & Drivetrain
    Last Post: 9th February 2008, 20:42
  4. Strange smell
    By masmit in forum Engine & Drivetrain
    Last Post: 24th August 2007, 21:22
  5. Strange smell when cold 1.9 cdti
    By sri22dti in forum Troubleshooting
    Last Post: 16th April 2007, 12:06
vauxhall vectra paraffin smell
cdti smoke and paraffin smell
zafira paraffin smell
astra 1.9 cdti burning smell
bad smell coming from inside Vauxhall Vectra site:www.vectra-c.com
