Thread: Fog lamp replacment
    Jul 2009
    Norwich
    Default Fog lamp replacment
    intermittently had the warning light saying my left fog is out on a 56 plate vectra estate. It comes and goes with the weather and by the look of it there is some condensation in it. The handbook gives instructions for other bulb replacement but says the fog is a dealer job! How difficult is it? Is it just a bulb or is it a sealed unit?
    R.
    Presumably front fog?
    Get down on floor. Look up under front bumper and you'll see a screw on cap at the base of the fog light. Park one wheel up on a kerb to give better access if nesessary.
    Twist cap in direction that arrow shows to undo. Unclip bulb and disconnect wire (pull spade connector out of socket). Refit is the reverse of pulling apart.
    You can get a snorkel kit to solve the condensation problem, but one of those moisture absorbing bags you find in shoe boxes, some electrical goods boxes, etc work just as well if you lay it in the base of the cap before refitting.
    Jul 2009
    Norwich
    yes, front
    thanks for that. wonder why they make it look like its difficult. What's a snorkel kit? Never heard of it although I have some silica bags knocking around so probably won't get one.
    R.
    Quote Originally Posted by rheumatoid View Post
    http://www.vectra-c.com/forum/showthread.php?t=47934
  1. Exhaust Replacment
    By Lozza in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2012, 18:45
  2. Air con compressor replacment
    By Rickiw in forum Engine & Drivetrain
    Last Post: 8th June 2011, 18:35
  3. Engine Replacment on 2.0DTI
    By ectraz in forum Engine & Drivetrain
    Last Post: 28th December 2009, 14:19
  4. Horn Replacment
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2009, 17:12
astra j fog condensation
