Results 1 to 10 of 18
Thread: GM spark plugs, need setting?
    Feb 2011
    Mansfield
    Default GM spark plugs, need setting?
    I get some plugs from the stealer for a heafty £35.
    will these be ready to pop straight in or do I need to set the distance, if so what.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Its worth checking that the gaps are correct - they usually come with a preset gap but as they are probably designated for several models / engines its best to check that they are right for yours - for what it takes
    Regular Member John Bishop's Avatar
    Oct 2010
    Always best to double check before fitting. 'Hefty £35' Try mine about £110! lol
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by JonJoe View Post
    Which engine do you have?
    £35 is very fair (less than £10 each) and relatively cheap
    Other types are probably available, you get what you pay for...
    As above, always, always, always, check prior to fitting
    6 Post(s)
    If they're multi electrode plugs, don't attempt to alter the gaps. You'll never get them all the same. A spark will travel across the shortest gap, and thus prematurely wear out the plug if it's only using one of the multi electrodes all the time.
    In short, only attempt to regap single electrode plugs.
    Feb 2011
    Mansfield
    it is a 2.2 direct if that helps, anyone know what gap they should be
    Oct 2010
    Not sure but could be 1.0 - 1.2 mm
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Seems a bit expensive for a set of plugs - Im in the Vx Trade Club and according to the book (although its a couple of years old now) there are two types for the 2.2 the GM33 or the GM37 - the 33 are £2.41 +vat the 37 are £3.24 + vat each - although they will probably have gone up a bit.
    Perhaps someone else could give a more recent price.
    There's also a set of NGK plugs for the 2.2 for £12.98 with free p+p on Fleabay
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Heres the tc price m8
    Z22SE - £2.44+vat each
    £11.74inc vat
    retail price is £4.44+vat each
    £21.31inc vat
  1. Best oil and spark plugs
    By Sri-chris in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2011, 02:36
  2. Which Spark Plugs
    By spennny in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:38
  3. 2.0t spark plugs
    By SRI-RICH in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2008, 18:02
  4. spark plugs
    By Morephun in forum Engine & Drivetrain
    Last Post: 1st October 2008, 06:37
  5. Spark plug setting
    By mark1319 in forum Engine & Drivetrain
    Last Post: 7th August 2007, 20:35
