Thread: strange ambient air temp
    Nov 2007
    lancashire
    Default strange ambient air temp
    getting a fault on me 1.9 cdti, when i plug in opcom i get a high ambient reading of 215c which is a little high, outside temp reads -40c so i think a wiring fault somwhere but where to look first??????
    Engine : 1.9 CDTi
    Do you have a pre or post facelift?
    Nov 2007
    lancashire
    Pre face lift
    Engine : 1.9 CDTi
    Check the condition of the front bumper plug near to the nearside fognight
    Nov 2007
    lancashire
    did that first still the same readings
    Engine : 1.9 CDTi
    So you checked the multi plug (Not the sensor plug) for corrosion and it was fine?
    Nov 2007
    lancashire
    only checked senser plug and not checked anywhere else yet,but when senser was unpluged it still showed the same readings. will check the plug further up the harrness when im back with the car as im away till thursday.
    Feb 2011
    Selby
    The fact that it gives the same reading when unplugged tells you that there's a break in the connection somewhere.
    And on pre-facelifts, it's almost certainly going to be the connector block that the temperature sensor circuit goes through at the bottom of the bumper in front of the radiator near the passenger side foglight, which is exposed to all kinds of water, slush, salt, dirt, oil, mud and spilt screenwash.
    Unplug that, and clean all the corrosion and muck off the connections then see what it does.
    Nov 2007
    lancashire
    well think ive found problem, seams when i had radiator fitted 12 months ago he trapped the wiring for the outside temp. wire had been rubbed through with the weight of the radiator on it. ten mins with soldering iron and it seams ok so will see what happens now. cheers for everyones help
    Engine : 1.9 CDTi
    Nice to hear you got to the bottom of it.
  1. ambient air temp sensor fault
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2011, 08:49
  2. Temp guage behaving strange, thermostat probs?
    By PeterVV in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 19:06
  3. Outside Ambient Temperature?
    By Draggon in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2010, 12:08
  4. Ambient lighting
    By Derek Mc in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2010, 12:11
  5. ambient light.
    By frasedeb in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2009, 11:22
