I've got an 06 plate Vectra C hatch, I have seen some wheels I like (18") and wondered if ET30 8x18" is OK, or whether the offset needs to be closer to ET40.
iirc the correct offset is between 38 - 45, using spacers could be the way forward with these wheel's to make them both look and feel right, just make sure the centrebore is right and add spiggot rings if too big, and if over 5mm spacers get longer wheelbolts
hth
The offset on these wheels causes them to stick out 16mm more than standard so I wouldn't recommend adding wheel spacers as that would make the situation worse.
I use this website to check if wheel and tyre combinations will be suitable.
