Results 1 to 3 of 3
Thread: Wheel offset?
    Sep 2011
    Winsford, Cheshire
    Default Wheel offset?
    I've got an 06 plate Vectra C hatch, I have seen some wheels I like (18") and wondered if ET30 8x18" is OK, or whether the offset needs to be closer to ET40.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    iirc the correct offset is between 38 - 45, using spacers could be the way forward with these wheel's to make them both look and feel right, just make sure the centrebore is right and add spiggot rings if too big, and if over 5mm spacers get longer wheelbolts
    hth
    Midlands Mod Shop - NFFC.
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    The offset on these wheels causes them to stick out 16mm more than standard so I wouldn't recommend adding wheel spacers as that would make the situation worse.
    I use this website to check if wheel and tyre combinations will be suitable.
  1. wheel offset
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 16:43
  2. Minimum Wheel Offset(ET) on Vec?
    By OPC in forum Suspension, Wheels & Brakes
    Last Post: 27th October 2010, 23:35
  3. Wheel Offset
    Last Post: 11th August 2009, 18:35
  4. Wheel offset calculator
    By Big-Pete in forum Reference Library
    Last Post: 30th April 2009, 20:24
  5. wheel offset
    By cookiejar31 in forum Styling
    Last Post: 15th September 2008, 15:11
