Results 1 to 10 of 19
Thread: Tyres Splitting and odd sizes
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Tyres Splitting and odd sizes
    My front passenger side tyre has started to split. I know it's a budget tyre as it was fitted to the car before I bought it. The tyre tred is still very good. Should I replace asap? Also I have just put tyre pressure in all the tyres and that same tyre was down to 27psi. Also what tyres pressures you lot putting in your 19" wheels? I am putting in 39psi in the fronts and 35psi in the rear as the user manual says. I have just been outside and noticed the front passenger side tyre is 245/35 ZR19 93WXL and the front drives side is 235/35 ZR19 91Y. That can't be legal?
    Engine : 1.9 CDTi
    Tyres need to be the same on each axle IE same on front or same on rear.
    I run 39 all round on mine.
    Whats the date code on the tyre?
    Feb 2006
    North East Uk
    How do I find the date code? I am running Avon tyres on the rear and I am thinking about getting the same for the fronts. I just can't believe they have different sizes on the front. I have never noticed that before till now. Thanks
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Change Asap not legal. They cuts/splits look dodgy as well. What make is the one in your pic?
    3.2 v6 Signum and loving it
    Feb 2006
    North East Uk
    Its a Primewell budget tyre, it came on the car when I bought it. I will replace it asap as I don't trust it. Thats the one thats the odd tyre out from the rest in size.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by Mark2.2 View Post
    I was wondering if that was a remould. I will ask about it tomorrow.
    Engine : 1.9 CDTi
    In the example above:
    DOT U2LL LMLR 5107
    DOT U2LL LMLR 5107 Manufactured during the 51st week of the year DOT U2LL LMLR 5107 Manufactured during 2007
    You have confirmed the outside edge of the tyre has cracks, what about the inside edge?
    If this too has similar cracks, then it has been caused by underinflation (see below)
    Ideally, the tyre would be removed and fully examined
    This is to determine whether the cracks are solely on the external rubber or if they have penetrated right through to the carcass
    Quote Originally Posted by Johnsdutton View Post
    What exactly makes this tyre illegal?
    If it is solely the cracks, then that is not the case as they need to be certain dimensions and these are no where near that yet
    For MoT this would simply receive an advisory
    For mixing tyre profiles, this is also acceptable but NOT recommended
    As above, this would be a MoT failure, but it is NOT illegal
    Sounds to me like the previous owner has been cutting costs and fitting part-worn tyres
    The cracks could also be age related and checking the date code will then certainly help
    Personally, as they are on the front just wear them out and then choose one specific tyre size and specification (probably what is currently on the rear)
    Engine : 1.9 CDTi
    Not the tyre itself but being different size on the same axle
    Glasgow
    The 2 front tyres are different widths and also one is xl load rated and one is'nt this alone is illegal.
  1. splitting on a flip key
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2012, 21:05
  2. Splitting door cards
    By R2XPT in forum Styling
    Last Post: 14th September 2011, 06:39
  3. 2.0t boost hoses which are prone to splitting
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 21:05
  4. Coolant header tanks splitting?
    By MadOnVaux! in forum Engine & Drivetrain
    Last Post: 6th December 2010, 22:26
  5. tyres mixing sizes
    By johnturbo in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2008, 13:26
