Thread: Fuel gauge fault???
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default Fuel gauge fault???
    Hi
    Does anyone now where the connections are for the fuel gauge?
    i put £35 pound in today and the light stayed on and the gauge didnt go up until
    about 10 mins later, this isnt the first time this has happened.
    anyone else experienced this??
    Many thanks
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Had it ones mate filled to the top couldn't get a penny more in I left it and it's bin fine since I bet the float was stuck as it was properly low as u said the light was on
    taunton
    yes mate iv experienced that try taking number 17 fuse in the fuse box on the side of dash and give it a little clean and pop it back in and go from there.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    The conections for most cars are usually on top of the tank. Can be a pain to get to. Some older cars used to have a cover in the boot, which you removed to access theelectric connections and the float valve in the tank. Not entirely sure about the Vectra though, usuall a good spray with wd or similar was enough to sort the problem.
    3.2 v6 Signum and loving it
    Ipswich,.UK
    thanks, its happened a few times and i think once i had half a tank and the gauge went down and the light came on, thought i was loosing diesel on the road lol.....
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sender unit on the blink.
    Engine : 1.9 CDTi
    Lift up/out the rear seat base and you will see a circle cut out in the carpet.
    Its under that.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Thanks Lee I thought it would be under the boot or thereabouts.
    taunton
    from what iv seen on here try number 17 fuse if not under the bonnet on the right hand side there is what they call a ABS block now I disconnected the battery for this you unplug and put in some electrical cleaner and put back together reconnect battery and try that now the worst case if it still doing it I ended replacing the dash clocks and not cheap
    This is quite normal
    Typically happens once every 100 fills
    We get complaints from people as well, "Just filled up and my fuel tank gauge reading hasn't moved"
  1. Fuel Gauge
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2013, 09:40
  2. Fuel gauge fault???
    By Mads in forum Engine & Drivetrain
    Last Post: 28th January 2012, 19:02
  3. fuel gauge
    By vauxie in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 21:00
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Replies: 2
    Last Post: 15th September 2008, 23:18
vectra c fuel gauge fuse
faulty fuel gauge on signum
opel vectra c 2004 fuel gauge
vectra c fuel gauge problems
vectra c faulty fuel gauge
vectra c fuel gauge not correct
faulty fuel gauge vauxhall vectra
2009 vectra fuel gauge going up and down
vauxhall vectra fuel guage going up and down
