Results 1 to 2 of 2
Thread: 1.9 CDTI Fuel non return valve help
    Regular Member 2wheelstu's Avatar
    Feb 2012
    Warwickshire
    Default 1.9 CDTI Fuel non return valve help
    I am contemplating installing a non return valve in my fuel line, to try and cure the syarting issues that i am having. Can anyone tell me what the bore size of the fuel line is please. I have seen 6mm,8mm and 10mm valves are available, and i'm not sure which one i need.
    Z19Dt engine 1.9 cdti (120)
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Can't help you with the size required - I looked into doing this myself while having starting problems with my 1.9cdti 120 - there are several different sized ones on Ebay but all those I saw stated they were only suitable for low pressure systems so watch that. Fitting it into the feed line could be a problem as the pipe is a hard nylon type, but I'm sure other members will have done this mod, and could help. Keep us informed how you go on.
  1. non return valve
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 24th January 2012, 22:21
  2. SITREP - Alternator, EGR Valve, Low Fuel
    By mk4 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2011, 02:57
  3. 1.9 cdti sxi 2005 Fuel metering solenoid valve circuit????
    By Gaz_chandler33 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 23:47
  4. estate fuel return pipe
    By DaveG in forum Engine & Drivetrain
    Last Post: 25th October 2010, 16:49
  5. Non Return Valve
    By woteva in forum Engine & Drivetrain
    Last Post: 27th January 2009, 15:47
https:www.vectra-c.comforumshowthread.php161114-1-9-CDTI-Fuel-non-return-valve-help
terex vectra non ritarn valve
corsa cdti fuel non return valve
insignia return fuel valve
non returne fuel valve vectra
fuel return valve for vectra 2006 diesel
fuel return valve vectra c
