Thread: Snapped door pin rod!
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Snapped door pin rod!
    Yesterday when I was cleaning out the car I had the passenger door open my jacket some how managed to end up over the door pin. I turned around and then heard a clunk. I just thought the door pin had came off the rod it sits on but when I went too refit it there was a bit of the rod (about an inch long) that the plastic door pin sits on stuck inside the door pin!
    I stripped the door panel off & ended up putting it back together as i couldnt see any way to fix this apart from replacing the rod.
    Am I right in thinking that I'll need to replace the full door lock mechanism? There's a couple on eBay for about £15.
    I couldn't believe it when it happened.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Do you know anyone who does copper brazing? That should do the trick.
    3.2 v6 Signum and loving it
    S.Lanarkshire
    I think it would be possible to weld it but my local friendly welder who stays next door is currently at the golf in USA so that's me snookered.
    I've ordered a second hand door lock mechanism from eBay for £15 hopefully it'll be simple enough to swap over.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Just had another thought for a tempoary repair. Use an electrical block connector, the type with the screws onto each end of the broken rod. i know that would be dependant on space behind the door card and length of the rod , but worthwhile looking at.
    S.Lanarkshire
    Quote Originally Posted by Johnsdutton View Post
    That's a brilliant idea
    Wish I'd thought of that before I bought a door lock solenoid from eBay.
    Just been out for a look I've lost the little orange clip that goes into the door pin! Can't find any on eBay either looks like I'll need to go to Vauxhall for 1. Unbelieveable !!!
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Just wish I had thought of it earlier.
  1. Cabling to Drivers Door Snapped
    By odubhuidhe in forum Vectra C / Signum Troubleshooting
    Last Post: 19th June 2012, 18:44
  2. Snapped exhaust manifold/turbo stud snapped in cylinder head!
    By XPCobra in forum Engine & Drivetrain
    Last Post: 7th May 2012, 10:50
  3. Oh no i've snapped it
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 16th June 2010, 18:14
  4. Fan belt snapped after 16k?
    By averdigi in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 20:16
  5. Spring snapped
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 12:15
