Thread: Is there an oil expert in the house?
    Regular Member sheepish's Avatar
    Yorkshire
    Default Is there an oil expert in the house?
    I'm off to buy some oil in Hlaford easter sale, Castrol Magnatec 4litres for £17.50. They have both the Vauxhall and Ford versions for sale.
    Now, the Vauxhall version is ACEA A3 B3/B4 (and GM LL etc.) and the Ford is ACEA A1 B1 or A5 B5 (and WSS-M2C-913-C, etc). As I change my oil every 10k and am not concerned with the long life bit, would the Ford version prove a more fuel efficient oil???
    I found this (see below) at http://www.driverstechnology.co.uk/oils.htm and the A5 includes A1 fuel economy with A3 performance???
    ACEA
    This is the European equivalent of API (US) and is more specific in what the performance of the oil actually is. A = Petrol, B = Diesel and C = Catalyst compatible or low SAPS (Sulphated Ash, Phosphorus and Sulphur).
    Unlike API the ACEA specs are split into performance/application catagories as follows:
    A1 Fuel economy petrol
    A2 Standard performance level (now obsolete)
    A3 High performance and/or extended drain
    A4 Reserved for future use in certain direct injection engines
    A5 Combines A1 fuel economy with A3 performance
    PRESTON
    I see where you are coming from, but personally i would be using the Vauxhall version oil. To me it's a case of better safe than sorry. I look forward to seeing others views on this.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As above wouldnt really want to try something else.
    I mean you'll probably be perfectly fine with others but just in case.
    I use vxls own fully synth oil an change it every 7k
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    I cant see why you couldnt use the A1 spec, as the VX spec one is just to aid it achieve the 20,000 mile service intervals that the Vec has.
    As these are all fully synthetic oils, you won't notice any difference in fuel efficiency, the difference will be so small it will be negligible
    As you plan to change the oil and oil filter every 10K miles you can use any synthetic oil down to 10W40
    You could swap from fully synthetic to part synthetic, but that would simply be a personal choice and cost consideration
    Compare :
    A
    original service interval 20K miles / 1 year or 20K miles / 2 years or 30K miles / 2 years
    Oil costs £30 to £60, oil filter costs £40
    B
    10K miles
    Oil costs £20 to £40, oil filter costs £20 (After Market version)
    As mentioned numerous times, this is personal choice, and from the above the costs don't really matter
    It is only a consideration whilst the car is under 100K miles / a warranty applies or can be applied in the future
    Just as an aside, we recently started stocking the A5B5 oils, intended for Volvo but can be used in most other vehicles
    If you want some reading, pay attention to the Kinematic 100'C :
    http://www.opieoils.co.uk/pdfs/castr...w-40-a3-b4.pdf
    http://www.opieoils.co.uk/pdfs/castr...0-fst-a5b5.pdf
    http://www.opieoils.co.uk/pdfs/castr...-0w-30-fst.pdf
    http://www.opieoils.co.uk/pdfs/castr...-oil-a3-b4.pdf (this would be my recommendation from the Castrol range)
    Yorkshire
    Thanks for this.
    So comparing the datasheets for the Magnatec 5W30 Ford and Vauxhall kinematic viscosity @ 100’C, the Ford version is 9.46 and the Vauxhall is 11.43.
    So if I’m reading this correctly, the Ford version is the ‘thinner’ of the two?
    Mar 2012
    Hampshire
    I picked up the 4L Castrol Magnatec for Vauxhall yesterday.
    Bargain at 17.99 considering they are also selling 1 Litre of it for 10.99.
  1. some expert advice
    By delberto in forum Handling & Braking
    Last Post: 14th December 2009, 11:45
  2. Expert help advice please!!
    By fowlerdf in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2009, 17:12
  3. looking for a flymo expert!
    By pogo in forum General Chat
    Last Post: 5th July 2007, 08:41
  4. Heating Expert needed!!!
    By SignumPhil in forum General Chat
    Last Post: 12th April 2007, 16:14
  5. Photoshop expert required
    By thegoldenbullet in forum Photoshop section
    Last Post: 25th March 2007, 14:30
