Thread: Power Steering Fluid Change
    N
    Default Power Steering Fluid Change
    Hi All,
    Power Steering on my car (53 1.8) has been quite notchy so I'm going to replace the fluid. I've located the bottle but could someone let me know:
    1) Best way to drain? - Take it out froom the bottle or just unplug the return pipe?
    2) WHich oil to use - I know I should be using the green mineral stuff, but even at halfrauds they sell a PAS & CHS 11? Not sure what to use and since dealer is closed today, they won't be much help.
    3) How to Bleed - I think i remember reading that its a case of starting the car 3/4 times, and then turning the steering wheel lock-to-lock 3/4 times? Could someone confirm?
    Regular Member Keif's Avatar
    In the Garage
    I asked the same questions in Feb, didn't really get much info.
    http://www.vectra-c.com/forum/showthread.php?t=155566
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Take pipe of and allow to drain out top up.
    Then do lock to lock several times holding at each lock for a second or 2.
    Not sure what fluid to use from Halfords I used vauxhalls own stuff
    as critch says
    and you can use any normal ATF ( automatic transmission fluid) as its the same
    N
    Keif saw your thread - but unfortunately didn't get much info from it
    Well i checked in the Halfords book instore and it says:
    1.8 2002-2005 Use Power Steering Fluid
    1.8 2005-2008 Use Central Hydraulic Fluid
    Any ideas? Vx closed so can't get it from them. Also whats the capacity - need to know how many bottles to buy!
    Thanks!
    N
    In case its of any use to anyone...
    The halfords Power Steering Fluid is actually Red (hence not the stuff you need). The Central Hydraullic System is Green (and the stuff you need!).
  1. Power steering fluid.........
    By Sway in forum Engine & Drivetrain
    Last Post: 18th December 2012, 20:06
  2. Which power steering fluid ??
    By FatboySteve in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 10:07
  3. Power Steering Fluid Change
    By Das in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2010, 20:57
  4. power steering fluid
    By madp06 in forum Engine & Drivetrain
    Last Post: 13th February 2009, 11:40
  5. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
vectra c power steering fluid change
power steering fluid change on a opel corsa c
opel vectra C 1.8 2002 servo fluid
vectra desiel steering fluid change
vectra c servo oil change
opel 1.8 steering fluid capacity
opel steering fluid replacement
vectra steering hydraulic drain
vectra c sefvo oil change
how to bleed power steering fluid opel corsa vauxhall
vectra c power steering fluid flush
how often should power steering fluid be replaced in a vauxhall insignia
vauxhall vectra power steering fluid spec
vectra c power steering fluid bottle
how to drain steering wheel fluid on vectra
vectra c 2002 how to change power streering fluid
CHS fluid for vectra c
vauxhall signum steering fluid change
https:www.vectra-c.comforumshowthread.php161081-Power-Steering-Fluid-Change
vectra steering fluid change
vectra signum steering fluid capacity
howntondrain power steering fluid vauxhall vectra c
how to drain power steering fluid on vectra c
vauxhall vectra power steering fluid capacity
