Thread: display safe problem how can I enter code ?
    Jan 2012
    LONDON
    Default display safe problem how can I enter code ?
    cdc40 opera how can I enter code I dont know which one is AS button I couldnt see it any where
    Engine : 1.9 CDTi
    Have you just fitted it or has it just started to do it?
    milton keynes
    You dont have to input a code for cdc40 , you have a mismatched headunit , screen or dab unit.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Indeed - Kman is correct as usual.
    The display is not paired to the CDC40.
    You will need to refit the original display
    Then get the display, phone portal (if fitted), DAB unit (If fitted) and head unit divorced from the car
    Remove the old display
    Then fit the new display, and program it to match your car's set-up (air-con / ECC) etc. (If this bit is not done, then set-up cannot be paired to the car)
    Then pair headunit, phone portal*, DAB unit* and display into the car.
    Then finish any specific display / module programming.
  1. cannot enter radio code
    By richermark in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 00:44
  2. Cannot Enter Code into CDR2005
    By yoclick in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2011, 09:11
  3. how do i enter radio code plz
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2009, 17:38
  4. CCR2006 - How Do I Enter the Code?
    By Jezzy in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2009, 03:04
Enter the code display
cdc 40 opera display safe
