Thread: Little help needed please
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default Little help needed please
    Hello everyone ive been having a bit of a problem of late with what i think is the battery but any help would be grateful a little example is that i took the wife to the docs last week so i waited in the car turned off the engine and listend to the radio, 20 mins later she comes out and the car is dead and just ticks i leave it for 10 mins and it managed to start same if i clean the car if i leave the radio on after 20 mins it kills the battery would this point to the battery or is something else draining it ? I have checked the battery and its in great condition with the fluid marker green which means good so I done a diag report tonight and it pulled up a few problems
    U2103 - <Unknown DTC>
    U2139 - Invalid Data from CIM (Steering Column Module)
    B3916 - No Communication With Alarm Siren
    B1325 - System Voltage Low Voltage
    (03) - Not present
    B1330 - System Voltage Malfunction
    (00) - Not present
    B0000 - Vehicle Speed Signal, Malfunction
    The car sounded a little rough yesterday and i done a report then with no faults found then tonight i get all these so any help would be very handy thanks
    P.S I have wiped the fault codes and went for a drive and re-tested it no faults found
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try cleaning the earth point up from battery and also make sure cables are tight.
    Do you have a multimeter?
    bridgend / wales
    Quote Originally Posted by Critch View Post
    Yea tried both those things mate thanks my multimeter is in work
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    When you get chance disconnect batt.
    Making sure you know stereo code of needed
    Leave for a few minutes and see what it reads
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
