Thread: 1.8 SRi 57 plate ignition struggle
    New Member mossy_46's Avatar
    Apr 2012
    Ipswich
    Default 1.8 SRi 57 plate ignition struggle
    Hey all, I'm new here and needing some ideas. When I try to start my Veccy, most times it is perfectly fine, but occasionally it will struggle, all lights go off the dash except battery light, it struggles, then starts, but all displays seem like they hav had a reset, although CD plays from same place it left, time is ok, etc, but temperature has disappeared and then comes back after a couple of seconds. On some occasions it displays turn lamp signal but the lights all work fine. I am confused by this issue and concerned as to what it may be. I have checked all fuses, and just had a service done anyways, new plugs, oil n filter, fuel filter and air filter. Had new coil pack last year August time.
    Please suggest ideas for me to investigate. Thanks in advance all who can help.
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Try the spare key in case it's the imobiliser chip in the key
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    firstly i would check and clean all battery connections inc earth to body and starter motor, next check the battery with a multimeter then with it still connected to battery take some readings when cranking over they should have a series of simular readings if you have a odd reading every now and then it could be down to a worn segment in the starter motor causing an excessive draw from the cranking amps of the battery;i have seen this on many fiats over the years causing simular dial problems.. HTH
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i would get the battery and alternator checked fella see what levels are on the battery and what charge the alternator is throwing out then id check and clean the abs plug under the bonnet sometimes this makes the dash go funny etc
  1. No ignition
    By pud wayman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 01:26
  2. Struggle to start when cold and cloud of smoke
    By MattHD in forum Engine & Drivetrain
    Last Post: 25th July 2011, 17:06
  3. Tips on using the forum for ppl who struggle
    By azacbr6 in forum The 'Off Topic' room
    Last Post: 8th May 2011, 09:42
  4. The struggle to fit my HID kit
    By luke4487 in forum Electrical & ICE (including SatNav)
    Last Post: 20th December 2010, 17:55
  5. rear number plate lights on all time when keys in ignition
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 13:56
