Results 1 to 10 of 22
Thread: EML Fault Code PO136
    Oct 2011
    Aberdeen
    Default EML Fault Code PO136
    Hi Guy's, had the EML flash up for the 1st time since ownership and on reading the fault code it come up as:
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    Can anyone advise where to locate this and is there any cures or should i just get a new sensor?
    I have cleared the code and see how i get on.
    Cheers,
    New Member GsiAsh's Avatar
    Sep 2009
    west sussex
    not sure what engine you have.
    ive had problems with my 3.2 v6 sensor 1 bank 1 which is a lambda sensor in the exhaust but i had a vacum leak on my inlet manifold which was giving the fault
    Oct 2011
    Aberdeen
    Quote Originally Posted by GsiAsh View Post
    Its also a 3.2 V6 GSI - 2003.
    That makes sense if it's a Lambda sensor as i have just fitted a 2nd hand pre-Cat (rear) with the sensors already fitted. Typically i scrapped my old CAT with good sensors already fitted
    Anyone know if it's the top or bottom Lamda sensor on the CAT
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    Oct 2011
    Aberdeen
    Cheers Ste, i only ran the car for 2 days since CAT was fitted then been sitting in Body Shop for the last two weeks. I'll give it a good blast and try cataclean, i also only use VPower which should keep everything tip top.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    just tying to find more info
    i read somewhere you must buy an original vauxhall lambda sensor dont buy a aftermarket one
    i will keep looking for you
    Oct 2011
    Aberdeen
    Quote Originally Posted by vectra ste View Post
    Your a star, i did try and search for some into on the code PO136 but couldn't find anything. If the sensor is needing replaced then it would be genuine all the way
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    i wouldnt buy an lambda sensor just yet give it a run and see how it goes take your scanner with you to turn the eml off if it returns
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 134000
    3.2 V6 GSI is one of my favourites
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
p0136 opel vectra c
po136
p0136 vectra c symptons
p0136 vectra c
p0136 signum
vauxhall zafira gsi p0136
code P0136 on vectra 2007
fault code P0136 on vauxhall vectra 2007
