Thread: 3.0 Diesel advice Pls.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default 3.0 Diesel advice Pls.
    Chaps - so looking at new car options now that my car has been written off..
    I defo want a Vec C estate diesel.. One of the CDTI's I think but wouldnt rule out a 2.2 DTI..
    Anyway - come across this:
    http://www.autotrader.co.uk/classifi...51sx?logcode=p
    With the 3.0 Diesel - is there a common issue that could cause the water loss overnight?? Just thinking could be a good buy if easy fix?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Water loss when driving or when stood still?
    If it loosing when driving. Like mine did less than 2 miles was head gasket.
    And unless you can do it yourself expect a bill of over 1300.
    Mine has a small external leak now. I suspect egr cooler gasket.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    To be fair that's pretty good price.
    I paid 1950 for mine last year needing a head gasket and that had 102 on the clock.
    You ideally need to pressure test cooling system to confirm where it's going.
    If your handy with spanners I could talk you through taking heads off.
    Or their is a lot of pics in the sticky my me in the 3.0 specific section
    Small external coolant leaks are difficult to source on diesels
    The main issue is the block remains hot and so the coolant evaporates
    Hence why most are found overnight or if the car is left for a long time to allow to cool
    I would be more concerned if the coolant leak is INTERNAL
    This would be confirmed by having to add coolant at regular intervals, with no external loss
    Mine went through this for a few weeks, but suddenly stopped
    I had to add about 100ml (in a 50:50 mix) on each occasion, and went through about 1/3 of a 1 litre bottle of coolant
    As above, start with a sniff test
    However if the liners and/or head gaskets have failed you may as well open your wallet and shake...
    edit :
    I see the price is £1285
    Ask the seller to perform a sniff test and report back
    Even if you spend £1000 on repair to the coolant system that is about its residual value
    Also why is the rear wiper arm missing?
    Ask the seller if it actually functions or is dead
    That will need to be replaced
    I'd offer £1100 as a result...
  1. 1.9 diesel/150 bhp - EGR advice please
    By paulf2012 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 23:52
  2. diesel leak - any advice
    By mooney in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 02:29
  3. Diesel tuning advice please
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2008, 14:46
  4. diesel tuning advice
    By georgehaynes in forum Diesel Engine related
    Last Post: 28th June 2008, 19:38
  5. Advice On Which Diesel Vectra-c
    By Irmscher Boy in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2005, 23:51
