Thread: warning lights
    Kirkcaldy
    Default warning lights
    Problem is that my vectra c is showing the 'bulb out' dislay on dash. I have checked everything, and all bulbs are working, but the warning continues to show on dash. Any hints?
    Regular Member Guss's Avatar
    Aug 2011
    West Malling, Kent
    hiya mate
    i had a similar problem with my siggy, mine showed me exactly which bulb was suppossedly gone....but what happes is that bulb is on its way out almost like an early warning that its going to blow.
    South east
    When a bulb fails, another one near to it illuminates in its place. E.g. when a brakelight bulb fails, the tail light bulb will work as the brakelight on that side, so if you don't look carefully enough you'll think both brakelights are still working fine.
    11 Post(s)
    Quote Originally Posted by Rebellion View Post
    Only applies to the brake lights and in some cases the front indicators take over the role of side lights. The rest of the bulb system doesn't have a helping partner.
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    i had mine come on the other day was saying rear right brake light bulb and checked the light and they worked fine took it out and the element had fell but soldered itself further down so the car picked it up as a fault was a weird one but there you go have a luck at the bulbs might be like mine
    11 Post(s)
    Quote Originally Posted by antowens View Post
    The resistance of the bulb had changed, hence why the bulb check picked it up.
    Dec 2011
    liverpool
    6 Post(s)
    ye so that might be why ians car is picking up a fault take a look mate
    Feb 2012
    Wrexham
    Default Brake Light
    I have a similar problem, put two new brake light bulbs in one of the looks a bit dimmer than the other .????
  1. ABS and ESP warning lights
    By ChristopheCDTI in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2011, 17:13
  2. warning lights
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2011, 17:09
  3. warning lights
    By jules in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 22:09
  4. warning lights
    By lee_car in forum Vectra C / Signum Troubleshooting
    Last Post: 30th October 2008, 14:01
  5. warning lights
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2008, 21:20
