Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 2.2 direct petrol 05. Fault codes
    west midlands
    Default 2.2 direct petrol 05. Fault codes
    There are so many threads about this but none of them really give an answer to my problems.So im hoping you guys can help.
    when i start my car and drive off there after a few seconds there is a slight misfire and the spanner light come on but it keeps driving normally (it doesnt cut out or go to limp mode)then after a few seconds the EML comes on and it starts juddering as if the spark plugs need changing. I have to then pull over and re start the engine and leave it running for a few minutes and it drives fine. This wont happen again until until i have parked the car up for a few hours. It has happened 5 days in a row now so im thinking it only happens on a cold start as when the engine is warmed up it drives ok.
    i have just had the car read from a friend who has a reader and the following codes have come up:
    P1112 Port deactivation solenoid valve
    P1101 Fuel rail pressure sensor curcuit
    P0302 Cylinder 2 missfire detected
    From the various post it could be 2 or 3 things but does anybody know for sure? i dont want to take it to Vx and get ripped off.
    i have had the Fuel pressure regulator replaced under recall from them already about 3 months ago and i replaced the plugs a few days ago so i dont think it is that.Are all 3 codes connected to one problem?
    Your help is appreciated
    west midlands
    have i put this in the wrong forum as no one has responded?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Could be swirl flaps, get some carb cleaner in her and see how that goes.
    west midlands
    sorry to sound dumb.can you explain the process? im not that of an expert in cars. lol
    Vehicle : SRi
    Mileage : 137000
    You just spray carb cleaner down the intake while the engine is running, take the intake pipe off after the MAF get someone to sit in the car and keep the revs up and bobs you uncle.
    west midlands
    thanks Mr Rush. ill give it a go
    west midlands
    hi guys
    im still having the problems as above so i took it to Vaux to find out the problem. just had a call and they said my High pressure fuel pump needs replacing AND something about getting my swirl flaps modified and replaced. im still in shock as they quoted me £1200!!! i havent got that kind of money!!
    i need advice please guys. is there something i can do as a cheaper alternative? can i get it done somewhere cheaper?
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    High pressure fuel pump off ebay about £250 to £300, three bolts and half hour at most to remove and refit, I had my swirl valves break due to excess build up of crud and one stuck and broke, there is a field remedy E0002233 where a kit is fitted to you original inlet manifold rather than replaceing the whole thing, cost me about £300 fitted, if yours arn't broken the try the carb cleaner route first.
    Full Member spennny's Avatar
    Blantyre
    If you can get access to a trade card mate then the pump will be cheaper,
    I have just called Vx Aldershot and asked for my price, they have told me its £303.36 ijnc VAT - so i would get it from there, give me a shout if you need to i have it reserved for 48 Hrs (Wip31156)
    and your correct, 3 bolts easy
    As for the swirl flaps i wouldnt have a clue
    west midlands
    why do they have that cheap and my vaux dealer said it was over £400?
  1. Replies: 6
    Last Post: 26th March 2012, 16:42
  2. Urgent Help please - 1.8 petrol error codes
    By m3ath3ad in forum Engine & Drivetrain
    Last Post: 27th October 2009, 18:38
  3. 2.2 Direct misfire codes- help please!
    By mostynmiller in forum Engine & Drivetrain
    Last Post: 27th February 2009, 20:31
  4. Sick Signum 2.2 Direct (Fault Codes)
    By kaston in forum Engine & Drivetrain
    Last Post: 13th September 2007, 10:31
vauxhall vectra 2.2 direct faul codes
