Thread: 2.2 DTI Auxiliary belt diagram
    watford
    Default 2.2 DTI Auxiliary belt diagram
    Belt has snapped, can anyone post a picture of the routing of the drive/auxiliary belt please, i am stuck, and tried a few ways but none work.
    Thanks in advance
    Nov 2010
    East Midlands
    Trim : design
    Hi, Struggling a bit on this one - this is for the 2.2dti Zafira - not certain it will be the same as yours but would have thought so. If you can give me year and reg no I'll do a bit more searching if this is no good.
    Nov 2010
    East Midlands
    Trim : design
    Right think this is the correct one for your car
    Which is similar to the Zafira above but has P/steering instead of idler.
    Are you ok fitting it?
    1. Jack up car and support
    2. You can remove RH road wheel for access but i didnt
    3. Just above the bottom pulley (biggest one) there is the tensioner
    4. On its backplate is a hex bolt, put a ratchet and socket on there and push anti clockwise. This will release the tension from the belt (but you have to hold it there)
    5. Slip off old belt.
    6. Slowly release tensioner.
    7. Fit new belt and when coming to the last pulley pull back tensioner with ratchet again to allow you to slip belt over the last pulley.
    8. Release tensioner
    The other thing to watch is did the belt break cleanly - or did it shred into strands - if it did shred be careful strands have not wrapped themselves around the crankshaft pulley and got onto the timing belt pulley - mate of mine had this happen and it threw the cambelt off.
    watford
    Thumbs up
    Done, those pics were spot on, thanks very much.
    Nov 2010
    East Midlands
    Trim : design
    Thats ok - glad your sorted and Welcome to the Club
  1. Auxiliary Drive Belt Diagram
    By den2712 in forum Engine & Drivetrain
    Last Post: 5th April 2012, 02:17
  2. Best way to change the Auxiliary belt
    By FrenchConnection67 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th March 2012, 19:43
  3. Auxiliary Belt Y20DTH?
    By Thom in forum Engine & Drivetrain
    Last Post: 14th September 2011, 18:29
  4. Auxiliary belt squeak!
    By Croxley in forum Engine & Drivetrain
    Last Post: 1st June 2010, 21:06
  5. Auxiliary belt
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 20:20
how to release fan belt tensioner on 2.2dti tid
03 vectra 2ltdi aux belt
vectra c 2003 2.2 alternator belt part number
Vectra engine pully diagram
opel frontera engine diagram parts
zafira dti fan belt diagram
zafira 2003 diesel fan belt giagrame
vectra b 2001 belt schematic
how to replace alternator belt on signum 2.2
saab 2.2dti belt diagram
vectra 2.2 tdi auxiliary belt
y22dtr fan belt
vauxhall frontera 2.2 dti belt tension
zafira dti auxiliary belt change
diagram of vectra 2.2 alternator belt
zafira 2.0 belt diagram
20 dti auxiliary belt route
2003 vauxhall zafira 2.0 dti belt diagram
astra g 2.0 dti drivebelt arrangement
vectra c 2.2 alternator diagram
vauxhall vectra 1.9 cdti alternator belt diagram
serpentine belt diagram zafira
Howto change alternator belt on vectra
y20dth aux belt
