Thread: Draining Coolant
    Default Draining Coolant
    Good Morning,
    Snapped the yellow cap off of the black coolant tank lid assembly. I applied an epoxy resin to the two parts and screwed the yellow cap back on to the header tank. Purchased a new cap off eBay. This morning I had to remove the cap to fit the new one. Unfortunately once I removed the cap chunks of epoxy resin fell in to the coolant in the expansion tank.
    I obviously want to remove these bits as I don't want epoxy resin chunks damaging anything internal.
    How do I just drain the header tank without having to drain the entire coolant system?
    Thanks for any help.
    East Ayrshire
    Trim : SRI XP1
    Take the big hose off of the bottom of the header tank. It'll pour out from there, but it'll do the trick
    Thanks mate.
    One quick question, there appears to be a metal clip on the hose at the base of the header tank, how do I unclip it?
    East Ayrshire
    Trim : SRI XP1
    Pair of pliers, squeeze the two tangs together and it will release. It's a good idea to have a jubilee clip at hand incase it breaks tho. Mine didn't, theyre fairly sturdy
    Thank you for your help mate.
    Done!
    Now all I need to do is top up with new anti-freeze!
    Do I need to bleed the system or is it as simple as topping up with anti-freeze and putting the cap back on?
    East Ayrshire
    Trim : SRI XP1
    You should be able to just top it up. To bleed it all you do is take it for a run with the heaters on full heat and full blow
    Thank you once again mate.
    All done now with your help. You can probably tell I haven't done much DIY on my own car!
    East Ayrshire
    Trim : SRI XP1
    Thats why we're all here mate. Got to help each other out
    11 Post(s)
    Quote Originally Posted by Lean6 View Post
    Do I need to bleed the system ?
    The purpose of a header tank is so that you don't need to bleed the system as any air will end up at the highest point of the cooling system - which just so happens to be the header tank. Hence why you only half fill it.
  1. Battery draining
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2011, 23:30
  2. Vactra computer screen draining battery
    By Gentari in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2010, 12:48
  3. Battery keeps draining
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2010, 15:08
  4. Draining Oil on a 1.9cdti URGENT!
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th October 2009, 21:22
  5. draining the water
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2008, 23:45
