Thread: Is the car drivable without drop links?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Is the car drivable without drop links?
    Dont mean forever... Bottom bolts nacked on these and just can't budge em, might just drive it to garage to get them cracked off.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Quote Originally Posted by leemarksmith View Post
    It will be awfull to drive mate rollin around like a pig but I drove mine with a snapped anti roll bar to my mates unit wouldn't recommended it like but tue answer is yes but be very carefully mate
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Just be careful because their will be no connection between each side.
    It will feel terrible to drive.
    Take it easy.
    And make sure you at least cable tie it out the way as last thing you want is it getting stuck
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Cheers guys (",)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Critch View Post
    Apart from a subframe
    Lee it'll be fine to drive short steady distances with out the arb connected as you wouldn't be throwing it into corners like a knob in this condition.
    All the arb does is reduce body roll when going into corners.
    I the thing I would be concerned about is if the drop links are still attached then they could become entangled in the strut, bodywork or wheel.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by John IS3 View Post
    I meant as in reaction for suspension so Cornering, bumps etc.
    Where you would usually get the reaction from anti roll bar acting to force wheel back down with the other wheel won't be their.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Yeah I won't be caining it, I drive like a nun anyway, try keeping it in 30+ mpg as only do short work journeys...
    Putting suspension back in tomo, I'll attatch the one side but drivers is still jammed so ill cable tie it out of way. get em changed wed once the other set are delivered...
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Just may sure that everything is going to be clear of the wheels bud as a stray drop link could do a fair bit of damage
    In a relatively straight line it will be acceptable up to 50mph
    Where you encounter corners you will want to keep to no more than 40mph
    Equally, after roundabouts or similar (where you have to turn the steering wheel left then right, or right then left) you may want to stop and check the bar itself has not become dislodged, but this is very unlikely if the bushes and clamps are still connected
    The main issue will be your insurance and road worthiness
    If involved in an accident then your insurer will be none too happy
    Therefore it may be appripriate to contact them in advance and discuss
    They may accept a short journey to/from garage for repair purposes only
    Alternatively they may apply a restriction until proof the repair has been completed, ie leaving you with only being able to move the vehicle by recovery agent
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Well it's been fine all week, taking it to the garage tomo as drop links finally turned up...
    One good thing, mpg has jumped up to 33, might take passenger side off too
  1. Drop Links
    By spennny in forum Engine & Drivetrain
    Last Post: 27th January 2012, 16:49
  2. Drop links or not!
    By goafer in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2010, 09:29
  3. Drop Links
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 20:06
  4. Drop links
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 21:45
drive without drop link
