Results 1 to 10 of 14
Thread: Help....snapped locking nut
    Regular Member themarbleman's Avatar
    sussex
    Default Help....snapped locking nut
    F*****get vauxhall locking wheel nuts, my brake pads and discs are shot and just started to take wheels off.
    The very first locking nut I go to and the damn key snaps.
    I have now lubricated them,driven to the local stealers and they can't help.
    Tried my local tyre fitter and he had no luck.
    The burning questions is does anybody local to chichester have a key i can borrow..109...
    The other one I will have to try and chisel off but at least I may be able to remove the other 3.
    Thanks in advance
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    F....ing annoying mate isn't it !! this happened with my old vec b absalute nightmare I knackered my alloy in the process . I would have thought the dealer could have got you another key . This would do the job for you http://www.halfords.com/webapp/wcs/s...egoryId_255216
    sussex
    Thought about going down that route but they have spinning collars which you still have to chisel off.I was trying approach the easier option first,you can buy a replacement key of flea bay.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Quote Originally Posted by themarbleman View Post
    Can you not welded another nut to the locking nut then crack it off that's what I do
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    The stealer sell replacement keys but better value in the locking nut set. If they dont have it instock, they will order you one in. My key snapped few months ago, the price of replacement key is £35, and a new set of locking nuts with key is £30. I went for the pack.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I did the same a couple of weeks ago i went to the stealers and they said they cant help cos i didn't have the part number for the key so i went to a garage and got them to weld it and they got it off for me with special nuts that when u screw them on they screw the bolt off
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Normally bits of the key break off in the bolt head - you can get the bits of metal out with a magnet, the actual bolt head may be OK
    See my post of 15 March
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Quote Originally Posted by Mark-R View Post
    The key number is imprinted on the locking key at the top where the wrench go over.
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    why do ppl still use vx lockers ...its beyond me ..
    sussex
    Got new key to remove the other 3 bolts safely, job done, the 4th one won't budge.
    How do I remove the spinning collar, sharp but knackered chisel? And hammer on a slightly smaller socket..
  1. Snapped exhaust manifold/turbo stud snapped in cylinder head!
    By XPCobra in forum Engine & Drivetrain
    Last Post: 7th May 2012, 10:50
  2. Snapped door pin rod!
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2012, 17:38
  3. Another snapped spring!!!!
    By mikeq in forum Suspension, Wheels & Brakes
    Last Post: 3rd August 2010, 12:15
  4. Oh no i've snapped it
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 16th June 2010, 18:14
  5. Snapped Spring
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2009, 14:51
